Pic of an extra part where does it go?
Discussion in 'Clock Repair' started by deena, Sep 30, 2019.
  1. deena
    deena Registered User
    Dec 2, 2000
    448
    Retired from position of Zoning Enforcement Office
    Rural western New York
    I dissembled a black forest picture frame clock and this tension clip fell out. Now I am not sure where is goes. In the photo I laid it on the plate. It is black, made from a strip of metal with both wings bent up. Any thoughts? 20190930_141305~2.jpg
  2. bruce linde
    bruce linde Technical Admin
    6,743
    815
    oakland, ca.
    probably under the hour cannon or motion works to provide just enough tension to the minute hand to keep it moving but not slipping.
  3. Uhralt
    Uhralt Registered User
    4,846
    575
    This is the clutch for the minute hand. It is mounted underneath the wheel that drives the minute wheel. This is part of the motion work outside the plate on the front of the movement. On top of the wheel with the spring underneath there needs to be a thin washer that is held with a tapered pin.
    deena likes this.
  4. shutterbug
    43,438
    1,232
    The spring "legs" should be toward the gear, not the plate, when you put it in.
    deena likes this.
  5. deena
    Dec 2, 2000
    448
    Thanks Bruce, Shutterbug and Uhralt. Now I can get back to work.
