Phillip Hauck
Dells
Oct 18, 2019
606
102
In the cotswolds UK
The Hauck that I purchased at Birmingham clock fair is all cleaned now and running just need to regulate it, very pleased with finished clock.
I must say setting the beat is a breeze on it, just a screw on the gimbal and plenty to hold and turn.
Dells
Oct 18, 2019
606
102
In the cotswolds UK
Thanks both
I am using the original torsion spring it doesn’t look like a Horolovar spring and the book said .0038 and I hadn’t got one only .0037 or .0040 so I have kept the original as it wasn’t damaged, but an .0038 seems a bit light to me but I have ordered some.
Dell
Schatznut
Sep 26, 2020
604
241
SoCal
Very elegant clock, Dells - nicely done! That pendulum is exquisite.
Reactions: Ken M
MUN CHOR-WENG
Sep 5, 2000
527
76
The 3-ball pendulum comes in two sizes as can be seen in the picture below. The one on the left has ball size of 3.25 cm in diameter while the one on the right has ball size measuring 3.08 cm in diameter. Lookinig at the picture posted by Dells above the pendulum appears to be of the larger one.
Mun C W
Dells
Oct 18, 2019
606
102
In the cotswolds UK
I must admit when I purchased the clock and picked up the pendulum it was a shock how heavy it was, that’s why I questioned the book saying use .0038 suspension spring, as Mun is saying there are two different sizes there must be two different size suspension springs.
Anyway the clock gained 30 minutes overnight set to full fast so it should be possible to get time set using original spring.
Dell
169,692
1,481,164
49,098
Heresolong
2,965
