Phenolic WWII Navy Clock Case
Discussion in 'Clock Case Restoration and Repair' started by wbranko, Feb 21, 2018.
  1. wbranko
    wbranko Registered User
    Feb 1, 2004
    388
    I have a phenolic black wwii Navy clock case with an unusual (to me) problem. I will post a couple of photos here. The case is phenolic plastic. However, it has a "rash" that looks like rust. In spots, this looks like it may penetrate the surface, and may be a brown phenolic material? It will not polish away with either Glayzit or Novus #2. Any suggestions as to how to remove this? Or is a coat of black paint in order? If so, lacquer or enamel? Thanks!!
  2. the 3rd dwarve
    the 3rd dwarve Registered User
    Nov 3, 2000
    659
    19
    Wbranko,
    Phenolic is a thermoset plastic. Dry powder is mixed with a colorant and sometimes a filler and poured into a mold. Heat and pressure are applied and the material crosslinks in the mold. Once the polymer is crosslinked it takes its form permanently. Shredded rag was used as a filler for phenolic resins as carbon black was used as a colorant.
    What you are looking at in your case are areas where the rag was pressed against the mold wall. No amount of polishing is going to change that look. You could paint over it but it is what it is, why hide it?
    D~
  3. wbranko
    Feb 1, 2004
    388
    D, Thanks...that answers my question! Now I'll decide what to do. Probably will clean polish, and put the clock back in after it gets serviced!
    Regards!!!
  4. MartinM
    MartinM Registered User
    Jun 24, 2011
    2,995
    86
    El Dorado, CA
    This might sound a bit crazy...
    But, would black shoe polish be an option?
  5. Uhralt
    Uhralt Registered User
    3,821
    375
    I find the look quite attractive. Looks like granite too me.
