Pendulums
Discussion in 'General Clock Discussions' started by classicbike99, Feb 2, 2020.
  1. classicbike99
    classicbike99 Registered User
    Jun 1, 2014
    21
    Can someone explain the workings of a pendulum. I understand length but why are they different weights (esp French clocks).
    Will a lighter/heavier one require less or more length
    will diameter make a difference
  2. THTanner
    THTanner Registered User
    Jul 3, 2016
    2,439
    154
    Carson City, Nevada
    Use the little magnifying glass up near the Donations button and key in "pendulum physics" - you will get more than enough hits to distract you from the Super Bowl half time and then some - this one link will get you started but probably not answer all your questions. As you look through hits on "pendulum" pay special attention to those from Tinker Dwight
    pendulum conumdrum.
  3. THTanner
    Jul 3, 2016
    2,439
    154
    Carson City, Nevada
  4. Willie X
    Willie X Registered User
    12,488
    864
    The bottom lines are: Too heavy, the movement won't power it. Too light and the pendulum will not adequately controll the rate of the movement. The length is a given, determined by the movement design. Willie X
    Now you can go watch the S Bowl ...
  5. classicbike99
    Jun 1, 2014
    21
