Most visitors online was 1990 , on 7 Feb 2022
Thanks So much for the responses! I do not know what I would need to next, would I need to understand what the current weight of the disk is to replace? or do I look for the counter weights to add to the disc I currently have? sorry if theses questions seem oddThese disks are not all created equal. Of two that I have at hand, one weighs 374 grams and the other 439 grams, both without any extra weights added underneath.
Eric
HiI thought you said you were missing a pendulum? I suppose there are a number of possibilities. Keep hunting until you find something like what Eric showed. Or if you do have a pendulum and you want to use it as a "marriage", then you'll need to figure out what suspension spring to use. If it were me, I'd probably consider a 0.004" thick spring. Try to set up some kind of rotation test stand outside the clock. Your goal is to have 8 beats in 60 seconds. Start counting "0" when the pendulum rotates to a stop going one direction. When it rotates to the opposite side, that's "1". Time it for 8 of those. If the time is less than 60, you'll need to go thinner. If it's more than 60, you'll need to go thicker. Be sure your pendulum adjuster is in the middle...the adjuster gives you some room to play with.
Kurt
Can you post a picture of what you have? I have some spare parts.Hi
I have the pendulum, is is missing one of the counter weights
That is a good question. The clock is at a clock repair shop, I can go and see and get back to you. Thank you so much for this help.That's easy enough. One has right hand threads and the other has left hand threads. Which one do you need?
Eric
