Pendulum swing
Discussion in 'General Clock Discussions' started by Zec Richardson, Aug 23, 2017.
  1. Zec Richardson
    Zec Richardson Registered User
    Aug 15, 2017
    10
    Blogger
    Essex UK
    I am not very knowledgable about clocks and after having wanted a proper clock for many years, I finally bought one.
    It is a HAC wall clock and I need some advice on the pendulum.
    At the bottom of the case on the back there is a brass plate with markings on and all I can think is that this is marking where the pendulum should be swinging inbetween. (of course I could be wrong).
    I have made sure that the clock is hanging straight and yet the pendulum swings more past one side of the plate than it does the other, if that makes sense?
    Can anyone offer some advice?
    Should the pendulum swing inbetween these markings and should I adjust the way the clock hangs so that this happens?
  2. dg23662
    dg23662 Registered User
    Jan 26, 2012
    86
    Retired electrician
    Poquoson Va
    You are correct. It is a beat scale. should have the same swing in both direction. you can hang clock to get the beat correct if it is not off very much, but most of the time we will move the crutch by slightly bending or shifting the pallet on clutch shaft. If clock was moved with pendulum hanging then the beat would be knocked off. Now let me say that I am a self taught clock worker. Start working and collecting clock after I retired. Don't let the bug bite you unless you have a understanding wife. Mind was fine with my first 15 or 20 but now that I have over 50 she gets a little angry when I get a new one.
  3. Willie X
    Willie X Registered User
    12,774
    982
    Often the plague is not positioned properly. To test it, line the plaque's (usually largest) center mark up with the pendulum tip. Check the clock's position on the wall, visually or using a level on the door frame sides. If the clock's position is good, your beat plaque is positioned properly. If not, the plaque can be repositioned, or you can make a small dot on the plate, with a Sharpe pen, to suffice. The beat can now be checked as dg24 just mentioned. When all is well the beat, the plaque, and the case's position on the wall, will all be true and in agreement.
    The plaque's primary purpous is to act as a carpenter's plumb bob. It's secondary purpous is decorative.
  4. roughbarked
    roughbarked Registered User
    Dec 2, 2016
    3,966
    341
    watchmaker
    The ear and I have only one that is failing, is the best listener.
    your click should beat evenly between numbers 1 2 3 4. if it goes 12 34, then you need to shorten or lengthen the gap, by ear.
  5. roughbarked
    Dec 2, 2016
    3,966
    341
    watchmaker
    #5 roughbarked, Aug 23, 2017
    Yes it does. If when you take the dial and hands off, you are presented with wires that appear to have been bent deliberately, then one of them has been accidently slightly bent out of shape. If you assure that your wall clock stays vertical by using a level and nailing the bottom of the clock to the wall via an attached bit of that old clock spring that has been mentioned elsewhere, then you may play with your fingers by bending the wires to the ear I have mentioned.
    or you could search the forum for beat adjustment or wait for a moderator to come along and fix this.
  6. harold bain
    harold bain Registered User
    NAWCC Member Deceased
    40,850
    154
    deceased
    The crutch should be adjustable without bending any wires to set the beat on this clock. It will be difficult for our poster to use your ears for this.:whistle:
  7. roughbarked
    Dec 2, 2016
    3,966
    341
    watchmaker
  8. bangster
    bangster Moderator
    19,633
    389
  9. Tinker Dwight
    Tinker Dwight Registered User
    13,666
    68
    You can make a note as to where the pendulum swing ends in
    each direction.
    Stop the pendulum and slowly move the pendulum in the direction
    is was swinging.
    You should hear the escapement action as the escapement pallet
    drops on the next tooth.
    Make a note where this happened.
    Repeat in the other direction and note.
    The distance between the ends of the swings and
    the end where it escaped, would be equal on each
    side if the clock was in beat.
    If the case was correct and the clock was in beat,
    the beat plate is positioned wrong.
    If the distances at the ends of the swings were different,
    the beat is not optimal for the mounted position of the
    movement.
  10. Zec Richardson
    Aug 15, 2017
    10
    Blogger
    Essex UK
    Okay, thank you all for the replies.
    I will see if I can use this advice.
    The clock sounds like it is in a perfect rhythm (if thats the term) and is keeping time well. So if this is the case should I leave it?
    If I correct this will it then cause problems and put it out of beat?
    But I know that the pendulum is doing this and so it annoys me.
    Seems odd that the pendulum is swinginging further one way than the other but is in beat.
  11. shutterbug
    42,723
    1,113
    It's not uncommon, Zec. That indicator may have been moved or misapplied at the factory. If it's in beat, be satisfied.
  12. Willie X
    12,774
    982
    Zec,
    Actually the pendulum ALWAYS moves the same direction left and right, measuring from the 'at rest' position. From your description the plaque is just out of place a bit. As already stated in post 3 and by others.
    Easy to correct, if you are so inclined.
  13. JTD
    JTD Registered User
    Sep 27, 2005
    7,233
    440
    I agree entirely with Shutterbug, WillieX and others, if the clock is in beat, straight on the wall, and keeping good time, then be happy and leave it be.
    If it really bothers you, move the beat plaque as has been suggested. In my experience, on mass produced clocks such as yours, the beat plaque was more for show and decoration than to be a exact gauge.
    I'd leave it be.
    JTD
  14. Zec Richardson
    Aug 15, 2017
    10
    Blogger
    Essex UK
    Thank you, I think that maybe best.
  15. Tinker Dwight
    13,666
    68
    Being in beat is a function of the movement and not the
    case or the bear scale.
    When most of us repair clocks, we try to closely adjust the
    beat of the movement to the level case.
    In many cases, to move the beat scale would damage the
    case.
    You can do what yo think it needs.
  16. Zec Richardson
    Aug 15, 2017
    10
    Blogger
    Essex UK
    I don't intend to move the plate.
    Someone mentioned the sound and they can tell if its okay by that, if I posted a youtube video and posted the link would someone then say yes or no as to whether it sounds right?
  17. JTD
    JTD Registered User
    Sep 27, 2005
    7,233
    440
    You can do that if you like but you really don't need to. You can listen to your clock yourself.
    First of all, you have already told us that the beat is even and the clock is running well.
    You have read the 'Beat Setting 101' lesson, so you know what putting a clock in beat means. All that anyone listens for is an even tick-tock, tick-tock, and you have that already I believe. A clock which is out of beat will sound uneven, tick-tock or tick-tock.
    If your clock is running well and sounds as it should, stop worrying!
    JTD
  18. MartinM
    MartinM Registered User
    Jun 24, 2011
    3,039
    95
    El Dorado, CA
    Many clocks, such as the venerable ST #2 have a pendulum that hangs somewhere other than the centerline of the movement.
    This means they also won't hang in the direct center of the case.
    If you want the beat scale to read correctly (or, at least, evenly), you need to either move it to match where the pendulum hangs (with the case being level) or hang the case slightly off level and adjust the verge to get an even beat.
  19. bruce linde
    bruce linde Technical Admin
    6,336
    691
    oakland, ca.
    on the ST#2 the movement IS mounted off center to the case, but the hour/minute canons, second hand and verge are lined up perfectly vertical... and centered. the pendulums on my three ST2s all hang centered on the beat scales... as they do on the two 61a movements i also have (same movement, 30-tooth escape wheels, seconds pendulums).
  20. MartinM
    Jun 24, 2011
    3,039
    95
    El Dorado, CA
    All true.
    But, the suspension post in the iron bracket that the pendulum hangs from is mounted slightly to the right of that line.
    At least it is in my examples.
  21. Zec Richardson
    Aug 15, 2017
    10
    Blogger
    Essex UK
    Oh damn, I hate admitting to being ....well stupid, but I have to here!
    I opened the door to wind the clock today and saw....
    yes two screws that are tightened by hand when loosened the clock mechanism can be moved left or right and yes you have guessed it.
    The clock isn't sitting dead centre, I then closed the door and saw that indeed the face is slightly off in the cotout of the door and I hung my head in shame and embarrasment!
  22. JTD
    JTD Registered User
    Sep 27, 2005
    7,233
    440
    Never mind, we've all done that (or something like that). You've learnt all sorts of things in your search for the solution and you'll know for next time.
    And isn't it a nice feeling when the problem is solved, even if it did take a while!?
    JTD
