Hi, I have a Dumoulin Neuf aH Molle mantle clock stamped 858, I'm looking for a replacement pendulum suspension spring to replace the one that has broken. The one I have measures (A dim) 5.12mm wide by (B dim) 24.83mm to ~25.07 length (estimate), with two side by side lengths of suspension spring (C dim) ~9.73mm long (estimate) (1.45mm wide x ~0.03mm thick).
Which one do you recommend?
