pendulum hitting weights
Discussion in 'Clock Repair' started by MuensterMann, Jul 16, 2017.
  1. MuensterMann
    MuensterMann Registered User
    Mar 23, 2008
    902
    Any particular tricks to get a pendulum further away from the weights so that it doesn't hit them? Movement is 451-050A. Not sure if they come with different post lengths. Thanks!
  2. Willie X
    Willie X Registered User
    8,143
    32
    #2 Willie X, Jul 16, 2017
    Yes, you can buy these in several different lengths. I usually go digging in the ole scrap pile.
  3. dickstorer
    dickstorer Registered User
    Oct 19, 2010
    567
    Retired Military
    Hampton, Georgia
    How much farther do you need the pendulum to hang? Some times a new hole can be drilled and gain almost a quarter inch.
  4. R&A
    R&A Registered User
    Oct 21, 2008
    3,302
    What diameter are the weights that you have ?
  5. Tinker Dwight
    Tinker Dwight Registered User
    13,680
    As a last resort, you can get some chunks of teflon an push
    the chains or cables off a little to clear. You can mount them
    to the bottom of the seat board. You can't get much this way
    with cables but chains are relatively forgiving.
    Modifying the pendulum post is another option, as a last resort.
    The correct diameter weights is the right way.
  6. MuensterMann
    Mar 23, 2008
    902
    The diameter of the weight shells is about 1 3/4". I am switching around pendulums on two grandfather clocks as I suspect the pendulums were replacements (one too long, one too short).
  7. R&A
    R&A Registered User
    Oct 21, 2008
    3,302
    Well if the pendulum might have been replaced. The bob maybe to thick
  8. novicetimekeeper
    Jul 26, 2015
    5,011
    Dorset
    Is it possible you clock could be leaning forward or back? Though you might expect both weights and pendulum to remain parallel to each other they might not
  9. Tinker Dwight
    13,680
    Mounted at different heights, they would be parallel but not the same
    distance apart. They have to be real close to start with to end up touching
    on any typical angle for a tall clock.
    Tilting forward would make them closer, assuming the pendulum was
    mounted higher to the back.
Similar Threads - pendulum hitting weights Forum Date
DUFA Grandfather Clock- Missing Pendulum Clock Repair Saturday at 3:19 PM
Jauch 96 pendulum replacement??? Help please! Clock Repair Nov 10, 2017
Pendulum hitting in a Linden Humpback 3 chime Clock Repair Feb 15, 2016
Vienna Weights hitting pendulum Clock Repair Dec 4, 2011
