pedro_keith
New User
- Jan 24, 2023
- 4
- 0
- 1
- 66
- Country
I have an Hermle wall regulator. The movement is 351 - 830. 66cm 80.166
This clock has not been run for a couple of years and after a move to a new home, it has been sitting. I decided to get it out and try running it. I don't know anything about clocks, but after finding that the clock pendulum would not keep it going, I found a small piece of metal inside the case. After some research, I found that it was a part of a broken suspension spring. I ordered one from Emperor Clock works ( a 351 - which I believe to be correct for my movement?). In any event, it arrived and looked just like the one that was broken. I removed the movement and installed the suspension spring. I read about how to but the movement in beat, and after much adjusting, I now have a very nicely timed tick toc - evenly spaced. I sounds correct. Everything works on the clock - it chimes , etc.
The problem is that is running slowly. About a minute each half hour. I have moved the pendulum bob ( the round weight?) using the screw knob all the way up and it still runs slowly.
The clock will run on its own without the pendulum and I have been letting it run. I suppose my thinking is that letting it run all the way down a few times my loosen up anything that is hanging it up.
Sorry - I'm getting to my questions:
Will letting it run without the pendulum POSSIBLY loosen it up so that it can run correctly? Should I get a shorter pendulum for the clock? I really cannot afford right now to have a professional clean the movement. I'm trying to avoid this. I know that taking it to a pro is the prudent thing to do, but in the mean time is there anything I can do? A different suspension spring? (though the one I purchased is supposed to be the right one I would think. It is a 351 and it looks just like the one that was broken.
Will letting the clock run down without the pendulum a few times help this? Should I take to movement from the case and try and oil some of the pivots?
If I were to get a shorter pendulum, how would I order it? Does the 66 cm refer to the length of the pendulum? Should I just order what I see on the web as one that lists as one I could get as a 55cm, 48cm, 45cm, and on down?
Thank you reading this long post and please let me know what you think.
