Pendant Set Hamilton 912 help
Discussion in 'Watch Repair' started by Cecilia Dunn, May 4, 2012.
  1. Cecilia Dunn
    Cecilia Dunn Registered User
    Nov 23, 2011
    Hey all,
    I am overhauling a Hamilton 912 I got from an antique shop that I have taken all apart, cleaned, oiled, put back together and all was well with it running outside the case. The moment the movement went in the case, I lost significant amplitude and the watch refuses to wind with the crown and stem. I am thinking sleeve issue? Possibly shipper spring adjustment screw is out of whack? Any other thoughts before I go digging around my stem and sleeve?
    Thanks!
    Ceci
  2. Randy Beamer
    Randy Beamer Registered User
    Jul 5, 2011
    111
    Aerospace
    Marysville Washington
    Ceci.
    Is it running well in all positions on the bench, before you put it in the case ? Just trying to rule out anything in the bare movement prior to casing.
    And if that's a "yes", try loosening the movement screws a bit, and then move the movement ( cute, huh ? ) and see if it's an alignment issue between the movement and the crown/stem assembly. Maybe its just mis-aligned a bit, and binding.
    Sorry if this sounds simplistic,..just trying to rule out what I think could be issues.
    Best regards,
    Randy
Similar Threads - Pendant Hamilton help Forum Date
0s & 3/0s pendant tube thread - what is it? Watch Repair Sep 29, 2017
English verge fusee makes clank/clunk sound when pendant up only. Watch Repair Aug 14, 2015
Seth Thomas 6s Runs great in all positions except pendant up, bad position error Watch Repair Jul 14, 2015
Electric WW Elgin 16 size pendant down problem Watch Repair Apr 5, 2013
Hamilton 950 Pendant set Watch Repair Aug 17, 2004
