Most of it in the catalogues is called orangewood, but you can get beech or hornbeam as well. I guess anything with a close, straight grain could be used.What tree does Pegwood come from
The trouble with matchsticks, apart from being made of relatively soft wood, is that they're sometimes slightly waxed, which can end up in the pivot holes.Matchsticks are also usable.
That is true of what are known as waterptoof matches but I didn't say to use those. While one might carve several matchcticks before finding one strong enough to do the work, I've never used a waxed one. If at all I prefer to would use the longer matchsticks mean to be used to light barbecues with.Hi roughbarked,
