Patent Regulator Catalog Your Favorite
Ethan Lipsig
NAWCC Gold Member
Jan 8, 2006
3,045
4,100
73
Pasadena, CA
I recognize that the regulator in my Albert Potter probably isn't eligible for this litany of patent US regulators because, Potter, though an American, made this movement after he had relocated to Geneva and I am not aware of any patent protecting it, though I have never looked for one. Still, it is an interesting and unusual regulator, resembling the Mershon regulators shown in Posts 43 and 44. While it is clear how those work (moving the long regulator arm moves the short arm via a rack and pinion interface, it isn't clear how the Potter regulator works since it lacks that interface. I would be a grateful for an explanation. Having no watchmaking skills (or the courage to use them on this Potter if I had any), I cannot disassemble it to find out how it works.
Clint Geller
Gibbs Literary Award
NAWCC Star Fellow
Jul 12, 2002
2,960
3,666
68
Pittsburgh, PA
clintgeller.com
Looks like a Mershon's regulator with the rack replaced by a sleeve. The idea of the two designs apparently was the same: reduce the magnitude of curb pin motion for a given arc length of regulator index arm travel, thus in principal allowing finer adjustment of the effective hairspring length. Both designs may have been subject to some degree of backlash between the two parts of the regulator.
They look cool as Hell, though!
Rick Hufnagel
Just Rick!
Oct 25, 2018
3,097
5,294
Pittsburgh pa
The longer the lever, the easier it is to move the regulator a very small amount. That large scale on the barrel bridge represents a very very small portion of the center of a scale if it were on the balance cock. It allows more precise micro regulation. Easier to achieve than if you were trying to tap a short lever on the balance cock.
Many older american movements use a long lever. Yours is simply split which makes it much longer to get more fine regulation. The fulcrum is that 90 degree fitting that connects both levers.
I'm a visual learner... If this is offends anyone's intelligence I apologize but it's just an illustration showing how longer lever makes for a finer adjustment. Both of these lines are moved an inch, noted by the dotted line and the measurements at the top show how far it moved.
The longer lever offers a larger amount of control in a smaller window of adjustment.
Thanks for showing that it's really interesting.
Ethan Lipsig
NAWCC Gold Member
Jan 8, 2006
3,045
4,100
73
Pasadena, CA
Clint, you said that the Potter regulator "[l]ooks like a Mershon's regulator with the rack replaced by a sleeve." I'd be grateful if you explained this in more detail. Until then, I am guessing that what you mean is this: The sleeve is the little flange covering the top end of the short regulator arm. The sleeve has a channel in its underside in which the short arm fits. As the long arm is moved off center, the sleeve rotates towards fast or slow, pushing the short arm in the same direction. There is enough of the short arm in the sleeve so that it doesn't run out of channel wall even when pushed all the way to fast or slow.
If that's what you mean, the Potter regulator seems a cruder design than the rack & pinion Mershon.
Clint Geller
NAWCC Star Fellow
Jul 12, 2002
2,960
3,666
68
Pittsburgh, PA
clintgeller.com
Yes, that's what I meant, Ethan. I would agree that Mershon's rack and pin arrangement was somewhat more sophisticated than Potter's design. Perhaps your term "flange" is more ideally apposite than "sleeve," for the part in Potter's regulator.
Clint Geller
NAWCC Star Fellow
Jul 12, 2002
2,960
3,666
68
Pittsburgh, PA
clintgeller.com
Does anyone have a good picture of Fassoldt's regulator? It is very similar to Reed's whip regulator, sufficiently so as to motivate a lawsuit for patent infringement, except that it has no index scale.
Clint Geller
NAWCC Star Fellow
Jul 12, 2002
2,960
3,666
68
Pittsburgh, PA
clintgeller.com
Reactions: Old rookie
KipW
Mar 24, 2015
175
156
Stretching the 'American' theme a bit north - a Tisdall 16s from Canada (but likely a Swiss-made Tavannes). What's interesting is the (presumed) mechanism under the cock that must be required to make this work. I'm not taking it apart to look, however.
Jerry Treiman
Golden Circle
Aug 25, 2000
7,311
5,018
Los Angeles, CA
I think my favorite among my own collection is Duane Church’s 1892 patent star regulator (Pat.No.484,176), and in particular in its simplest but highly-finished form in Waltham’s American Watch Co. grade bridge movement.
Nathan Moore
NAWCC Business
Dec 29, 2011
508
1,105
93
Circa 1880's Illinois 106 - Wheeler's regulator. (Similar to Chalmers. Don't know which is considered "superior" and for what reason(s), but both were used on early Illinois.)
This regulator swap may be connected to one of the more unsavory stories in American horology. In 1881, Wheeler was arrested for rape after forcing a young female worker into a nonconsensual relationship. This situation caused Wheeler to essentially be ousted from the company, and the regulator switch would follow shortly thereafter.
The two regulator designs are very similar, and Chalmers even references Wheeler's patent in his own patent application, claiming an improvement on that previous design with a "novel arrangement of parts."
KipW
Mar 24, 2015
175
156
Nathan - some story! To err is human - to regulate is divine?
Jerry - is this the same patent (Church 1892) with a more elaborate treatment of the wheel - or?
Jerry Treiman
Golden Circle
Aug 25, 2000
7,311
5,018
Los Angeles, CA
Yes, same patent, just a little fancier. Waltham used the "embossed gold" patent regulator on most of their higher-grade '92 models and '99 models with a less-expensive flat steel star wheel on lower grades and smaller models. The highly-finished version I showed was used only on the first bridge models and Riverside Maximus, until they switched to a whiplash regulator for those grades. Sometimes the flat steel version received some ornamentation, such as on this '88 model "Diamond Express".
KipW
Mar 24, 2015
175
156
In defense of the "better mousetrap" concept - in spite of its near-universal application, it seems to me the Reed regulator (and its variants) is more than a trifle fiddly to adjust. The adjusting screw is not easily accessible and is a bit frail. I would think some of the other patent regulators are better in that regard, especially the later, spring-loaded version of Elgin's "traveling nut" setup. Please correct me if I'm wrong, but the Elgin TN is much easier to adjust, and unless the thread pitch somehow spoils the increments, as finely precise as the Reed - isn't it?
Rick Hufnagel
Just Rick!
Oct 25, 2018
3,097
5,294
Pittsburgh pa
After trying to adjust a Teske with the Hampden in the case .. the Elgin regulator is a joy. My poor grade 40 Hampden has scratches by the regulator from someone trying to adjust it while cased...
The older Elgin regulators have a slight bit of play to them.. which I realized when doing the gr. 455 that the spring loaded mechanism took care of the problem. Pretty nifty.
Clint Geller
NAWCC Star Fellow
Jul 12, 2002
2,960
3,666
68
Pittsburgh, PA
clintgeller.com
You could be right, Kip. One thing I wonder about is whether the ratio of curb pin displacement to index arm displacement differs between the two regulator designs. The smaller the ratio, the more precise the regulation ought to be.
Ethan Lipsig
NAWCC Gold Member
Jan 8, 2006
3,045
4,100
73
Pasadena, CA
I looked through my collection of about 300 high-grade European pocket watches to see what sorts of regulators they used. Most of them, even the highest-grade and most complicated watches, and even one "observatory" watch, had simple regulators, which implies that fancier regulators weren't essential to high quality time-keeping. Indeed, most of my English watches and a few of my highest grade Swiss watches don't even have regulators; they are free-sprung. I would appreciate your views as to how beneficial fancy regulators really are.
Among my European watches with fancy regulators, by far the most common were Reed's or variants on it. The next most common were Wilmot's or similar cam-type regulators. Here are examples of what I found, including the regulators on a few US watches.
Reed Variant Regulators
IWCs, Gruens, and other watches, such as this Hamilton 923 have "half-Reed" regulators and other variations on Reed's.
Hamilton 400s, South Bend 431s, and some V&Cs had Reed-like regulators but with the screw under the cock, akin to the second version of the Elgin C.H. Hulburd regulator (see post 42) or the un-identified watch in post 6.
Elgin-like "Screw" Regulator
We all are familiar with the Elgin 'screw" regulator. See post 65. The regulator on this JJ Badollet looks nearly identical to it.
In contrast, this V&C observatory watch regulator, while similar in concept, appears different at least in having a straight or straighter screw than Elgin regulators had. I have 3-4 other V&Cs with this regulator.
Cam Regulator
A number of my Swiss watches had cam regulators. Whether any of them actually is a Wilmot regulator, I do not know. Here are some of them.
Ami LeCoultre Rattrapante with Jump 1/4 Second Diablotine
C.H. Meylan
Patek Philippe Bingham & Walk PL "Extra"
Patek Philippe Harrington PL
Patek Philippe Cronometro Gondolo
Longines Extra Superior
Oliver-Like Regulator
The regulator on this Louis Audemars is Oliver-like. See post 3.
Movado Regulator
Movado had its own unique style of regulator, as on this Gubelin PL.
Clint Geller
NAWCC Star Fellow
Jul 12, 2002
2,960
3,666
68
Pittsburgh, PA
clintgeller.com
View attachment 663717 View attachment 663725 View attachment 663726
Cam Regulator
C.H. Meylan
Movado Regulator
Ethan, regulators are known to degrade isochronism, that is, the uniformity of timekeeping accuracy over the running period. That is the main reason why many very high grade watches eschew regulators. Mechanical watches may run differently depending on how they are carried. Also, the timekeeping characteristics of a watch may change over time as the mainspring and the lubricants age and the pivot holes wear, etcetera. So a regulator is a highly convenient, even if somewhat problematic way to compensate for these effects without recourse to a skilled watchmaker.
KipW
Mar 24, 2015
175
156
Clint, does that explain why many of the latest European pocket watches, fitted with modern Glucidar balances, Nivarox ("Elinvar"-type) hairspring materials, and white metal mainsprings do not have regulators? With isochronism better controlled through improved metallurgy, are traditional regulators obsolete?
On the other hand, what you said might also explain why the Reed regulator took over in our classic watches. NOT messing with the regulator (by laypersons and well-intentioned owners) by virtue of making it difficult, might be better than offering a regulator style that invites it?
KipW
Mar 24, 2015
175
156
In the spirit of the thing, if not in strict adherence - Here is the so-called "Micro Adjuster" used on the Russian Molnija 3602 for a short time in the '60s. These watches had/have most of the modern updates in metallurgy mentioned in post #70, so any regulator was somewhat superfluous. This one, I'm informed by those who know, was also a horrible design, which made little or no difference in regulation, was hard to use, and broke frequently. Strictly a useless marketing ploy.
Clint Geller
NAWCC Star Fellow
Jul 12, 2002
2,960
3,666
68
Pittsburgh, PA
clintgeller.com
I don't know, Kip. If the balance wheel is not bisected into two cantilevered arms, that should reduce the effect of changing balance speed on the moment of inertia due to centrifugal forces. But I doubt that the variation in centrifugal forces is the only source of isochronal errors, and maintaining isochronism was not the reason for regulators, anyway. In fact, regulators degrade isochronism.
I don't think Reed's whip was designed to discourage consumers from using the regulator. If that were true, Howard would not have reversed the handedness of Reed's regulator and the hairspring when case styles changed from offset front and back hinges to parallel hinges. The change in the regulator and hairspring handedness was effected so that one could continue to access the regulator without removing the movement from its case.
musicguy
Jan 12, 2017
9,964
7,425
New York State
Lets keep it to American regulators please:).
Rob
KipW
Mar 24, 2015
175
156
Let me tack a question onto this thread. Can experts out there please comment on something that puzzles me?
For instance: I have some Columbus 18s watches which sport two different patent regulators. One, although called a "Columbus Spring" on another website, is basically a variation of the Reed (US Pat#61867, dated Feb 5, 1867) and the other is a so-called "Owen" (US Pat#336060, dated Feb 9, 1886).
I think it's been reasonably established that the Reed regulator was/is the most successful design of them all. Yet, almost 20-years after it appeared on the horological scene, there was a period when American watch companies seemingly "sprouted" patent regulators of their own...sometimes several! Then, towards the end of pocket watch production, the last of these companies, notably Hamilton, Elgin, and Waltham, all reverted to the Reed type!
So - question 1 - Why should this be so - unless Reed was best in the first place?
Question 2 - Aside from personal opinion, is there factual support for the enduring success of Reed variations, either from a technical or financial perspective? Conversely, were all other patent regulators somehow inferior, in the end?
Question 3 - Back to my Columbus watches (or other manufacturers) where records are scanty, sketchy, and often wrong... can the type of patent regulator in use at the time the watch was made be used reliably to help date it or determine its grade - or at least determine an era? (Greg...HELP?)
I apologize - if this has been covered previously, but Hey - "enquiring minds" y-know? It just seems weird to me that most patent regulators seemed to disappear as RR standards got tighter. Whereas Reed-type variations were the "go-to" type, both in the beginning, along the way, and at the end. 1867-1970 is a pretty good run!
Greg Frauenhoff
Aug 25, 2000
5,258
3,619
View attachment 672185 View attachment 672186
For some companies, the regulator is certainly a clue as to the era. The Columbus ones you show are examples: left later, right earlier. Rockford also had a progression of different regulators on their 18s mvts. Early ones use a spring (some round, some heart shaped) similar in idea to Reed's regulator but then several more interesting ones follow. Aurora has a cool early regulator (designed by G. F. Johnson but not patented) followed by Hurd's. I will post pics as time permits (working on another project at present).
Allan C. Purcell
Feb 9, 2013
3,632
1,829
Germany
Allan, I don't think the Columbus regulator in the photo you posted resembles the Potter regulator. Because I am wholly unfamiliar with Columbus PWs, I do not know whether any of its regulators resembled the Potter regulator. What I do know is that the Potter regulator appears perhaps to have been inspired by the Mershon regulator on early Howards. For a discussion of this, see https://mb.nawcc.org/threads/patent-regulator-catalog-your-favorite.31979/page-2#post-1477161.
Hi Ethan, thank you for this thread, it is just what I was looking for. There is a small misunderstanding with your quote above. I was talking about the balance cock, not the regulator. More on that when the Columbus watch arrives from Australia. I have in the meantime started to take a closer look at the Regulators on the American watches I have here.
This one below is by the Fredonia Company, though even looking at the regulator file above, I have not been able to say who made it. I do like the fast, slow marks on the side of the balance cock. Not seen that before.
The next three photographs are the Waltham. On post 63 there is a photograph of this model in 1892. I think this one is earlier, 1884?
Running out of time will show more later. Really fantastic thread.
To be cont......
PS: The photographs are mine sorry, they could be better, will try harder.
Allan C. Purcell
Feb 9, 2013
3,632
1,829
Germany
So here we are back again, nicely rolled gold case and in it an Illinois watch company, 15 Jewels, Chalmer regulator, serial number 1067297 c1897.
Another Illinois watch, this time serial number 153902. I could not find this type for sure in "WATCHES" could be Model 1 Hunting, Key wind & Set.
Jewel count not given.
More tomorrow.
Allan C. Purcell
Feb 9, 2013
3,632
1,829
Germany
Today, two of the regulators used by Waltham. The first one, the serial number 2290240 an 1887 watch. Made in-house I believe.
Appleton & Tracy. Nice Dueber coin silver case with 14K hinges.
This one, on a P.S. Bartlett, the regulator is Fogg´s Patent. c1874-75. Coin Silver case Warrented by Waltham.
More to come.
Allan
Allan C. Purcell
Feb 9, 2013
3,632
1,829
Germany
Fascinating thread (just discovered it) :)
Hi Bernard, thanks for the likes, I am just learning about the use of regulators on American watches, and having a really good time wondering why they chose so many. My thoughts at the moment, are that they attracted customers, who knew nothing about the mechanics inside, but the Regulator could be talked about for hours with the seller. Easy to explain, but the buyer could be told how to use it, and if not they could come back with the certainty they would be put right. Plus they had a guarantee. These American regulators really stand out, when you compare them with the dull Regulators of European regulators at the beginning of the 19th century. Tompion, Boswell, Massey, and even the Breguet Curb. So away to learn more.
Allan
PS. If anyone wants to copy or use my photographs please do so.
Allan C. Purcell
Feb 9, 2013
3,632
1,829
Germany
Have a question? Do members think the compensated balance wheels were imported from Switzerland? (The early ones).
People like Dietrich Gruen and so? See the Illinois watch on post 79.
Tom McIntyre
Technical Admin
NAWCC Star Fellow
NAWCC Ruby Member
Golden Circle
Aug 24, 2000
85,185
2,918
86
Boston
awco.org
I was rereading Chamberlain's "Its About Time" this evening and read the chapter on the Otay Watch Co. and related work in California and Japan. In Chamberlain's story P. H. Wheeler is the hero of the unsuccessful effort. He is described as leading.
In it Chamberlain says
There exists a letter dated June 19, 1881 acknowledging his resignation from the Illinois Watch Co. signed by Charles Sivorowski, Secretary and Treasurer, which expresses regret and says that any time he desires to return a position will be open to him.
Chamberlain had apparently been able to talk to Wheeler's daughter and get quite a bit of family information. He later became Superintendent of Columbus Watch Co under Gruen and Savage.
The Otay story is pages 279 to 288 of Chamberlain's book and quite a bit of it is about the accomplishments of Wheeler.
Jerry Treiman
Golden Circle
Aug 25, 2000
7,311
5,018
Los Angeles, CA
Allan - the star-wheel regulator that you show in post #78 is not the same as the one shown in post #63. The regulator you show is a two-armed variant of Woerd's 1870 patent (Pat.No.110,614 - Patent Watch Regulator by Charles V. Woerd Issued Dec 27, 1870). It works a little differently from the regulator shown in posts 61, 63 & 64 is Church's 1892 patent (Pat.No.484,176 - Patent Watch Regulator by Duane H. Church Issued Oct 11, 1892)
Allan C. Purcell
Feb 9, 2013
3,632
1,829
Germany
Tom, Jerry, thank you for this information, I have spent the day reading up on these Regulators, and on top of that the "Watch & Clock Bulletin" turned up in the post this morning. Two photographs on the front page of early regulators in Edward Howard ladies watches, pity the regulators were not discussed. Great article though, by Alan Myers & Clint Geller.
So after running around all day like a chicken with no head, I have decided to consentrate Columbus watches, and in the main, their regulators. They were of course one of the very early firms, I hope then to be able to move on to others.
That article in "It´s About Time" by Chamberlain, I must have read it when I bought it some 30 odd years ago, but then I had little or no interest in American watches, so over all these years, I have skipped over it to the European stories. (One exception is De Long. that man was magic).
will pester you both again,
Fond Regards,
Allan
musicguy
Jan 12, 2017
9,964
7,425
New York State
Tom McIntyre
Technical Admin
NAWCC Star Fellow
NAWCC Ruby Member
Golden Circle
Aug 24, 2000
85,185
2,918
86
Boston
awco.org
I only have one Columbus (I think ;)) at this time (sold a few).
But I do really like the regulator on it.
Rob
Really neat private label. Since the town where Sing Sing is located is Ossining NY, did the owner of the watch live in the facility? :)
musicguy
Jan 12, 2017
9,964
7,425
New York State
musicguy
Jan 12, 2017
9,964
7,425
New York State
My favorite regulator is Johnson's with the keystone shaped spring as used on early high-grade Auroras.
I would never have guessed it would have been an Aurora ;)
Rob
musicguy
Jan 12, 2017
9,964
7,425
New York State
Very neat watch. FWIW, Aurora also made a private label for James in Sing Sing.
I know
I have only seen photographs of one other E T James PL and it was an 18s Hampden
serial number serial #409951 circa 1886 grade 60 15j. @Greg Frauenhoff also let me know
about an Aurora that also was from this same jeweler but I have no photos or further
information about it, he says it's a partial movement.
Rob
177,503
1,555,587
53,592
AndyB821
909
3,053
