Patek Philippe lady's pocket watch
myasnik
Newbie
Mar 3, 2017
148
66
Доброго дня everybody!
Again I ask for help in identifying the movement: who is the manufacturer of the ébauche?
Patek Philippe or maybe Audemars?
It's a lady's pocket watch, diameter of the movement is about 13''' (30 mm), h = 3.5 mm.
Serial number 58904.
Thanks in advance for the replies.
Best regards,
Dmytro.
Слава Україні!
photo_2023-05-29_15-52-32.jpg photo_2023-05-29_15-52-40.jpg photo_2023-05-29_15-52-41.jpg
Dr. Jon
Dec 14, 2001
8,080
2,413
New Hampshire
I believe this is by Patek Philippe. It has unique Patek features. You can be more certain by request an extract from the archives.
mosesgodfrey
Aug 30, 2017
693
585
93
Agree with Dr. Jon for possible finisher. I will add from seeing under the dial, it is likely a Husson & Retor ebauche. If it is serviced, ask for pics or to view it disassembled: there may be hidden marks from them on underside of or below bridges/plates.
myasnik
Newbie
Mar 3, 2017
148
66
Many thanks for the reply and advice.
But, firstly, 500 CHF is very expensive I think, and secondly, I would rather donate some money to the armed forces of Ukraine. This is more important to me now. Sorry for offtopic.
Sincerely,
Dmytro.
myasnik
Newbie
Mar 3, 2017
148
66
Thank you very much. I will do so.
Sincerely,
Dmytro.
myasnik
Newbie
Mar 3, 2017
148
66
One more question, if you please.
Does anyone know what this mark on the platina under the dial is?
Sincerely,
Dmytro.
mosesgodfrey
Aug 30, 2017
693
585
93
I believe it is simply “11” or “ii” (uppercase). Not sure it has any proven function, but I hope others may have a definitive answer for you.
SWAG: Personally, I think it could be a caliber setup reference for the ebauche maker. I’ll call it a “setup” number, because I’m ignorant of all proper nomenclature. :)Not always a caliber number per se, but used to direct machining. Beginning with the plate, each custom order would have a reference number (likely ties to the order number in the ledger) + the client’s serial number. But this third number could indicate which template(s) should be used for drilling the plate.
For example, at one factory I’ve studied most, this setup number controls (at least) the setting mechanism layout:
  • Identical movements from the back + different setup numbers = vastly different setting works
  • Calibers with the same setup number may have slight differences in the setting springs, etc.—but the drilling/milling of the plate below is identical.
Staff online
183,978
1,606,947
55,982
Adcrager
3,195
Top Bottom
