Part of a tall case clock
RickNB
Sep 15, 2021
154
67
75
I saw a pic of a clock with this part I have never run into before. Can anyone tell me what it is and what it does? (red tinted)
bwclock
Feb 17, 2015
504
386
I believe the primary purpose of that piece is to irritate clock repairmen. The secondary purpose may be to keep the leader from coming off the suspension spring, say, for example, when one accidentally bumps the leader upward when installing the pendulum. Likewise, when a clock is being transported with the pendulum removed the part will keep the leader from falling off.
The way you highlighted the part in your photo is a nice touch.
Bruce
19,608
4,657
It helps keep the spring from being broken and also keeps the leader from accidently unhooking. Willie X
RickNB
Sep 15, 2021
154
67
75
So my assumption is that you would slide it back out of the way when the clock is running. Right? Otherwise I could see it interfering with the suspension spring.
bwclock
Feb 17, 2015
504
386
I never moved it back. I would check to make sure the bottom block of the suspension spring was centered in the slot. If not, I would adjust the part so that the clearance was the same on each side with the pendulum swinging. The slot in the ones of these I have encountered is wide enough for this.
BB
19,608
4,657
No, it stays in place all the time. The locking thumbscrew drops into a recess in the post. There is no adjustment needed, unless your clock had been in a terible
accident. Willie X
183,956
1,606,739
55,964
S.K. Hawkins
3,190
Watch case by Kent
Top Bottom
