PAM Clock Motor
Discussion in 'Electric Horology' started by wbranko, Oct 18, 2018.
  1. wbranko
    wbranko Registered User
    Feb 1, 2004
    388
    I have a PAM clock that had an Ingraham motor in it. I assumed the motor was beyond help, and replaced it with a new Synchron motor and movement, which works fine. However, upon further investigation I found the Ingraham motor still works. The clock was in a Butcher shop for years and the motor and movement are completely fouled with meat grease (yeah...I know...gross!). I know how to deal with the movement, but ...
    The real question is how to clean the motor out and remove the meat grease? I assume I can not use an aqueous ammonia clock solution...but what CAN I use? Is a watch cleaning solution the answer? Or possibly something like Toluene (probably too agressive)?
    I would appreciate a tip/procedure from the experts. I will try to post a photo with this message.
  2. davefr
    davefr Registered User
    Nov 29, 2008
    421
    13
    Semi Retired Engr. Mgr - Currently Rebuilding Tele
    Oregon
    #2 davefr, Oct 19, 2018
    I'd remove the rotor core and clean it's shafts/pinion gear by hand. I would not dip the main body of the motor in anything since it's integrated with the coil. I'd probably put one drop of mineral spirits or naptha in the inner bushing and clean it with a toothpick. (repeat a couple times) After that, put one drop of very light viscosity oil in the bushing. (don't use clock oil!!)
    You could also use an aerosol electrical motor or contact cleaner since they don't affect electrical insulation.
    [​IMG]
  3. wbranko
    Feb 1, 2004
    388
    Dave,
    Thanks...great detailed response. I will give it a try!!
  4. Jenson
    Jenson Registered User
    Oct 24, 2018
    I had expel the rotor center and clean it's poles/pinion outfit by hand, i would not plunge the principle body of the engine in anything since it's coordinated with the loop, i had likely put one drop of mineral spirits or naphtha in the inward bushing and clean it with a toothpick...
    In three words I can sum up everything I’ve learned about life: It goes on
