Pam clock glass?
Discussion in 'Electric Horology' started by john48, Feb 26, 2017.
  1. john48
    john48 Registered User
    Jun 1, 2004
    157
    Hello all,
    Mostly work on antique wall, mantel, and Grandfather clocks. Friend brought me a round Pam light up clock with outside glass missing. Ordered the bubble glass through timesavers. With hands set as low to dial as possible and barely missing each other. Tip of Second hand still rubs the inside of domed outer glass, and makes that wet finger going around the edge of a glass sound:screwball: Question is: Was there some sort of spacer used between advertising flat glass, and outer domed glass that would have held it out slightly farther?:confused:
  2. harold bain
    Donor NAWCC Member
    39,946
    I would shape the hands to miss the glass. If necessary the second hand could be shortened. I often do this with slave clocks, putting a bend a few inches from the end of the hands, to ensure it clears the lens.
  3. Ralph
    Ralph Registered User
    Donor Sponsor NAWCC Member
    Jan 22, 2002
    4,391
    The original glass had a different profile.... flatter and then curved sharper as it gets neared the edge, if that makes sense.....effectively deeper and clears the end of the hands.
    Ralph
  4. john48
    Jun 1, 2004
    157
    Thanks guys for your reply! Hate to shorten the sec hand, in fear of it looking funny. Right now I have it the same length as min. hand. Would really like to bend end of sec. hand down . But it is very close to min. hand. Don't think I want hour hand rubbing flat glass😕 A slight spacer seems possibly the answer? But would need to stick to glass. Ralph, have you delt with this in the past?
  5. BLKBEARD
    BLKBEARD Registered User
    Nov 15, 2016
    617
    HVAC, MECHANIC
    CT
    Maybe looking at similar clocks on ebay or the like will give you a OEM glass profile to compare to your Timesavers glass profile.
  6. davefr
    davefr Registered User
    Nov 29, 2008
    350
    Semi Retired Engr. Mgr - Currently Rebuilding Tele
    Oregon
    As has been stated, the timesavers glass isn't the correct profile. It's spherical but you need the special profile used by Telechron and Pam. Return the timesavers glass and start looking on Ebay. I would not modify the clock or hands to use the wrong glass.
