Most visitors online was 1660 , on 12 Dec 2020
It’s more a “don’t mess with this” signal for the operator than a fix for anything mechanical.I (personally) don' expect that many will do this, because most mills have tension-levers to securely fasten the table/bed.
But if that (common) option is not available, this seems to be a good solution.
Hessel
To avoid misunderstanding:It’s more a “don’t mess with this” signal for the operator than a fix for anything mechanical
