• Upcoming updates
Orphaned 1800's Longines PW Movements - What To Do With Them?
John Hinkey
Feb 21, 2022
371
150
57
As a prelude to restoring my great uncle's 1880-vintage Longines pocket watch I bought 4 different movements of the same era for spare parts.
Well, it turns out that I didn't really need any major spare parts after all, but now I'm the owner of 3 decent movements, two of which are really very very nice.
See here:
This one is my favorite - the balance seems fine, but it won't wind (likely broken mainspring). Jewels look OK as far as I can tell.
It has a very nice dial too (the chip at the setting lever likely will be covered up by the bezel):
and this one actually seems to run fine (it winds up and runs - no idea how accurately), but it's much more dirty than the one above:
The dial is in perfect shape, though not the most fancy (it's also missing the minute hand, but that's not a big deal):
I'd love to restore these movements, but I'm having troubles finding suitable full silver cases (open or full hunter) that don't already have OK movements or that people aren't asking $450 for.
One or both of these could be candidates for my 3D printed pocket watch case project, but that's 3-9 months off.
Any ideas? Should I rebuild them both (and the 3rd one that's note quite as nice) and try to sell them? Keep them and keep trying to find a decent case?
Thoughts?
Thanks -
John
Reactions: Rick Hufnagel
Rick Hufnagel
Just Rick!
Oct 25, 2018
3,137
5,487
Pittsburgh pa
I've been sitting on two of these, one key and one stem, for some time now. Finding a Longines case is not exactly going to happen unless you get really lucky. I figure someday one will be sitting on a mart table that will fit (or close to it). Maybe not. But, they are still nice movements to work through and enjoy!
John Hinkey
Feb 21, 2022
371
150
57
Working on 3D printing a custom case for a couple of my orphaned Longines movements:
So this is basically a 3-part open face case (no clamshell) with sapphire crystals over the dial and the movement (which I don't have any detail of).
The winding stem is a bit murky on how to do that easily w/o using one from an actual case.
A lever set movement is a challenge.
I'm working on getting a FDM 3D print. An SLA-type print certainly can do this level of detail, but the available materials are kind of crap for making an attractive case.
These sapphire windows are only $35 each in this 1.500in diam. x 0.040" thickness size and is virtually unbreakable, especially mounted in plastic covers.
Working on the colors and more design details. Screws are M1.4 stainless.
Thoughts?
- John
Ethan Lipsig
NAWCC Gold Member
Jan 8, 2006
3,214
4,606
74
Pasadena, CA
John, I am not a movement collector, but I might become one if there were a ready supply of 3d printed cases to protect and display them. I hope your efforts are very successful!
John Hinkey
Feb 21, 2022
371
150
57
I'll let everyone know how this goes. It may take a few months to work this out. I found a few more aesthetically interesting movements (movement and/or dial) on ebay that are apparently working and either have no case at all or are in a terrible ugly case and are candidates for putting in a 3D printed case to bring back to life.
Here's the latest version with the hands and a quick 2mm thick bow:
John Hinkey
Feb 21, 2022
371
150
57
The movements made for the US market may fit US standard cases. It is worth measuring the dials to see if they match US sizes
Unfortunately this particular Longines movement dial and main plate diameters are 40.75 & 40.60mm respectively, which doesn't correspond to a standard American case size (check marked rows) according to this chart:
Hence the problem finding decent cases for these. Plus many of these Longines movement can be found only with really beat up silver (sterling or 0.800 silver) cases for $500 or so as opposed to $250 or so just for the movement (including the dial and hands).
So even if these movements were a standard size, it would still be difficult/expensive to find one that fits ESPECIALLY for a lever or pin-set movement.
Reactions: Bernhard J.
mosesgodfrey
Aug 30, 2017
502
399
...So even if these movements were a standard size, it would still be difficult/expensive to find one that fits ESPECIALLY for a lever or pin-set movement.
For the odd sizes, look for dust rings that neck it up. Or 3D print one!
For standard, my reco is to look beyond Longines for cases. I’ve sourced many handsome sterling, niello and coin cases from no-name watches for well under $100 that are correct period and style for my orphans. Some under $30. Most Longines for US import were cased here anyway. And those no names are where you’ll find a higher saturation of pin set. Lever set is often a manageable case mod.
You’ll have some misses on sizes, but for the right (cheap) price you can afford to miss. Plus, having a quality case on hand—accurately measured by you—will be all too easy to fill.
John Hinkey
Feb 21, 2022
371
150
57
Yeah, I thought about the next size up in cases, for my particular case it would be a size 14 or 16 for the first Longines movement pictured above, but I have the problem of cases not coming with the winding stem - particularly since it requires a female square hole winding stem and crown that will fit.
I suspect I would have better time fitting in the movement with the size 14 as then I have a chance that the bezel will fit closely enough for the lever set.
So where does:
  • One find size 14s or 16s coin silver or gold-filled hunter cases for level set movements?
  • One find a compatible (both with the movement and the case) winding stems?
Thanks -
John
svenedin
Jan 28, 2010
1,941
705
Surrey
Very interested by your ideas for pocket watch cases. I have many orphan movements and I gave up looking for cases for them long ago. They sit in drawers in plastic movement cases similar to Petri dishes. It's shame but I have far too many complete watches anyway! On the other hand, a rugged case that was waterproof too would be marvellous.
John Hinkey
Feb 21, 2022
371
150
57
Yes, my idea is to maybe figure out how to quickly make interesting modern cases for these movements that show off the dial and the movement and still be a fine time piece. Some made for myself, some sold to others - either the case and the movement together or make custom cases for each movement.
I'm trying to get a demo from a 3D printer manufacturer to show how fine the surface finish of the case materials will be as well as how well the parts will fit together (dimensional accuracy).
Stay tuned.
John Hinkey
Feb 21, 2022
371
150
57
If it is possible to print a hand gun that works, surely a well sealed watch case shouldn't be too difficult.
Oh, for sure.
For me I want to make sure it will look good - i.e., have small enough layer lines that it's not noticeable and be durable.
Also, I want to keep the printed case near in size to what it would be for a metal case.
The winding stem and case tube are difficult to print because of the traditional thin metal in this area, so it needs to be thicker when made in plastic.
The winding stem might have to be special made metal because of the high torque during winding if I can't find donor winding stems that are compatible with the movement.
The other thing I need to incorporate are the internal thin metal spring strips that are used to keep the movement stable/centered in the case. These can potentially be printed integral with the case (hence the beauty of 3D printing).
So the first printed version might not be pretty, but once you figure out all the details re-printing a final version is easy.
- J
svenedin
Jan 28, 2010
1,941
705
Surrey
There’s also the issue of positive and negative set watches. My orphans are a mixture of both. Positive set would be easier as all the setting components are in the movement.
John Hinkey
Feb 21, 2022
371
150
57
I have not heard the term "positive set" and "negative set" - please explain more!
- J
Dr. Jon
Dec 14, 2001
7,708
2,122
New Hampshire
Positive set watches have a setting detent that engages the setting yoke. The pendand does all the work. A thicker ring on the stem lifts teh setting mechanism.
Negative set watches have spring which in the movement which drives the stem out to the setting position. The stem has a notch cut around it. When the pendant is in, a spring holds the notch notch keeping the stem down in the wind position. These holding springs are a disk type in a sleeve which threads in the pendant. This system was used in most American pocket watches with stem setting. I do not think this English French or Swiss used it except in rare one-offs.
If you convert an American case to hold a Longines it may he useful to remove this setting sleeve and spring from the pendant, which is easy to do with a special sleeve wrench.
BTW if you want to get into case making Steffan Pahlow has published a book on making cases. It is far more modern that the Martin Matthews methods and include an example of one made of plexiglass.
It covers all the critical fits and how to achieve them. He has also posted a series of videos on a case he made for a fairly complicated watch.
Reactions: John Hinkey
John Hinkey
Feb 21, 2022
371
150
57
Thanks for the reference to Steffan's stuff. Unfortunately it seems his book is unavailable at the moment.
What a craftsman!
Dr. Jon
Dec 14, 2001
7,708
2,122
New Hampshire
The NAWCC library has two copies in German one is available for loan to since you are a member.
The books is lavishly illustrated so not being able to read German is not a deal breaker, especia;l;y if you watch his YouTube videos on making a case.
John Hinkey
Feb 21, 2022
371
150
57
Expanding this to other orphaned pocket watch movements.
I just purchases a cool-looking Tavannes with great dial and the stem.
which should look very nice once cleaned up. This is stem set/stem wind and so enables a more simple 3D printed case design.
It will wind and does run just a bit - I just got it yesterday and the balance seems fine, but there is hardly any power making it to the escape wheel since it take about a second for the escape wheel to move if you push the pallet fork back and forth.
So hopefully this just means a new mainspring and a full cleaning.
I have two other Tavannes pocket watch movements (between them I'd make a running version) that I have my eye on over at ebay that seem to be good candidates due to the dial+hands and very nice movement details, though they are case set/stem wind versions that I will need to find the correct Tavannes-compatible stem and case
So I'm going to 3D print cases for my Longines spares (maybe two of them) and perhaps two Tavannes pocket watch movements.
I'm having a test 3D filament print done this week on just one part and we'll see how that goes.
- John
Rick Hufnagel
Just Rick!
Oct 25, 2018
3,137
5,487
Pittsburgh pa
Hey John,
Measure that Tavannes, you might be able to get it into an American case. A number of their movements were available as positive or negative set and available overseas. It's worth a look.
John Hinkey
Feb 21, 2022
371
150
57
Hey John,
Thanks for the idea. What specific measurements do I need to ensure that this movement will fit into an American size case if all I have is the case size (12s, 16s, etc.)?
Thanks -
John
John Hinkey
Feb 21, 2022
371
150
57
Anyone else have a source for detailed case measurements for each size case so I can make sure my movements will fit before buying a case?
Thanks -
John
John Hinkey
Feb 21, 2022
371
150
57
I have just taken possession of a few more orphaned PW movements - both Longines from the later 1800's. Lever set.
Clearly they had their cases melted down. Both seem to work and are in really great shape. Perfect candidates for 3D printed cases (which I'm still working on and should have a prototype out soon), especially since they come with the winding stem/crown.
$130 for both - that's crazy!
John Hinkey
Feb 21, 2022
371
150
57
So it seems that I'm noticing more and more very very nice orphaned movements that appear to be in great shape - I assume this is because their cases have been melted down for the gold/silver. Shame.
Hopefully I can make something nice from these movements.
My 3D printer has been in get to know the resin printing process & dimensional calibration mode - hopefully soon I'll start putting out some prototype 3D printed cases for some comments back. First ones will be boring designs, mainly meant for functional checks.
- John
Incroyable
Jun 26, 2022
654
309
Would it be possible to draw out the precise measurements on a computer and then use a CNC machine?
I know jewelers often use this method for certain things.
John Hinkey
Feb 21, 2022
371
150
57
Yes.
I'm measuring the movements to be able to make a custom fit case. I use Solidworks CAD for my modeling.
CNC machining of a case is very expensive due to the 5-axis capability needed, hence I'm trying to 3D print a polymer case which can be done in hours as opposed to many days. Plus 3D printing allows quick iteration.
Clearly plastic vs. stainless/silver/etc. is a big deal, but one thing that plastic offers is shock resistance and the ability to quickly replace the case if damaged. Also plastic can be gold/silver plated for appearance if necessary.
Current 3D printed polymers are actually very very good materials - much better than what people typically use for printing figurines.
I think if one wanted to make custom metal cases then the best way to go would be to use a 3D resin printer to make high resolution casing molds to then cast with silver. Though there would still be a large amount of post casting hand work to make the casting, if the casting was successful, pretty.
Incroyable
Jun 26, 2022
654
309
Yes.
My feeling is that plexiglass or something resembling lucite would be a very modern take on a pocket watch case without the aesthetic compromise that base metal cases often have.
John Hinkey
Feb 21, 2022
371
150
57
Yes, I have designs using a fully transparent resin material with sapphire glass for the crystal as well as for the transparent back to view the movement.
Reactions: Incroyable
John Hinkey
Feb 21, 2022
371
150
57
Hi John,
Yes, there a couple of copies listed on Bookfinder.com in Germany, and both are in German. I know that there were English editions printed.
Ah, I speak English and French, but alas my German, despite my last name, is non-existent.
I will try again to hunt down an English version.
Dr. Jon
Dec 14, 2001
7,708
2,122
New Hampshire
Have you check with Pahlow directly. He published privately and do not whole sale the book.
I bought my copy from a dealer which surprised him. I bought that way because his site required a bank transfer which cost $40.
I like the guy a lot and he deserves a good return for his work. If you have not tried to email him you should
John Hinkey
Feb 21, 2022
371
150
57
Here's the very first prototype 3-part (front cover, main case, back cover) 3D printed case. Totally experimenting.
The front and back covers get glass or sapphire windows/crystals and very small screws hold the assembly together - see CAD images further up this post.
This is for that 1880's very lovely vintage Longines stem wound/lever set pocket watch movement that I have a picture of up at the top of this post.
These parts need a final cleaning, supports taken off the main case body, then UV+thermal curing to stabilize and harden them.
Then windows get UV glued in, 1.4mm threaded screws installed, a stem+crown installed, etc. and we should have a first cut prototype.
More to come:
The front and back cover windows will be 38mm diameter x 1.5mm thick. The whole case is about 55m diameter.
- John
svenedin
Jan 28, 2010
1,941
705
Surrey
I’m very impressed. I have lots of excellent orphan movements that I would like to use. I also like the fact that the case is plastic. My watches are in gold or silver cases and I do not like them getting scratched. With a plastic case I wouldn’t care. The ultimate would be a waterproof plastic case. Then I could go hiking in the mountains with a pocket watch. At the moment I have to transfer my pocket watch to a waterproof ziplock bag if it rains.
John Hinkey
Feb 21, 2022
371
150
57
Some images with the movement temp. mounted just to see what issues there are that need solving:
John Hinkey
Feb 21, 2022
371
150
57
I realise there may still be some minor issues but at first glance to put it in Australian vernacular; it looks bloody beaut mate.
You have convinced me that buying orphaned movements does have a future.
Next step is to get that regulator to sit in the middle.
Lots of tweaks to this design to get it to fit - need to get it to mount in properly (it's close), get a stem and crown, figure out the bow and how to strongly attach it, mount the crystals, etc.
I'm modifying the design to have a flat-ish bottom where the hinge would normally be so that it can stand on a flat surface.
Lots more to come. I also need to try some different (hopefully better) materials and optimize the resin curing process.
Stay tuned.
svenedin
Jan 28, 2010
1,941
705
Surrey
You are doing well and I am loving all of it.
I would add, If you want better waterproofing on the visual crystals, why not tru hetting that straigh bezel edge like those that use the mineral or indeed sapphire crystals? So that you can factor in the waterproof crystal seal they use. There are standard measurements for this.
I second that!
DaveyG
Mar 21, 2005
2,553
197
76
North Wales, UK
Inspirational. I do hope that others follow your lead John - otherwise you could find yourself (too) much in demand ;) .
I definitely echo the sentiments expressed by roughbarked and, like many others I guess, I have a lot of candidates for re-homing.
Incroyable
Jun 26, 2022
654
309
If these were large movements you could also make them into desk clocks or even paperweights.
John Hinkey
Feb 21, 2022
371
150
57
I would add, If you want better waterproofing on the visual crystals, why not try getting that straight bezel edge like those that use the mineral or indeed sapphire crystals? So that you can factor in the waterproof crystal seal they use. There are standard measurements for this.
I'll look into that. The crystals will be UV glued in and as such will be very waterproof. There is room for an o-ring on the front and back parts, though the lever set opening is the weak link in preventing water or debris from entering the movement. Working on an alternative way of gaining access to the lever to set the watch that is more elegant and resistant to allowing water/contamination to get inside.
Also this model has a flat bottom to allow sitting it upright on a desk.
Here's the current CAD model:
John Hinkey
Feb 21, 2022
371
150
57
Current version - design changes, 3D printing, fitting, changing design/changing 3D printing settings, iterative cycle.
Hopefully have an assembly soon with the movement installed:
The setting lever is tricky to provide access to. A tethered rubber cover/plug would be nice to plug up the access slot and keep stuff out of the movement.
Incroyable
Jun 26, 2022
654
309
If you figure out the basic design could you simply tweak it for different movement sizes?
John Hinkey
Feb 21, 2022
371
150
57
Likely.
There is the complication of lever set versus negative stem set versus stem set variations along with the associated stem type and size (length and diameter) that needs to be accommodated.
Also, the location of the movement retaining screws are all over the place from one movement to the next.
Should have a complete prototype assembly next weekend or so. The front and back covers take about and hour to print (at the same time) while the main body takes ~9hrs to print. Trying to find a compatible stem for this movement as opposed to printing one (won't be strong) or making one (time consuming)
180,059
1,570,759
54,364
clockminded
911
3,090
