Original Mainspring Dimensions -HAC W77 Movement
Discussion in 'Clock Repair' started by Chrisb, Aug 25, 2018.
  1. Chrisb
    Chrisb Registered User
    Oct 9, 2015
    Engineer
    Fourways, Gauteng, South Africa.
    Hi All, Could anyone please advise what the original dimensions were for the mainsprings fitted to these movements in the Going and Strike trains at the time of manufacture ? The movement is marked as follows:
    W77 over
    "Crossed arrows", ie 'HAC', bottom left hand side of rear plate.
    187/35 over
    83, top left hand side of the rear plate,
    345, (date code ?), top right hand side of rear plate.
    Movement is Time and strike, only.
    Many thanks in advance,
  2. Willie X
    Willie X Registered User
    11,990
    692
    Well, I can give you some tips to go on.
    Width is a given, 1mm less than the space available. Strength is the big question mark. On German clocks the strike spring is often thicker than the time spring by 1 to 3 thou. Once the strength/thickness is chosen, the optimum length can be calculated.
    Do you have any parts of the old springs, this would help a lot. At least you would have some reference. If not, a good guess (or starting point) would be 15 thou for the time and 17 thou for the strike. The calculation will yield the correct lengths for the respective barrells. Assuming the barrels are the same size the time spring will probably be about 10" longer that the thicker strike spring. Willie X
  3. Chrisb
    Oct 9, 2015
    Engineer
    Hi Willie X,
    Many thanks' for the response, much appreciated.
    Unfortunately, there where no springs with the Movement to work from. I recall that what is usually found in the USA movements on the strike side is: 0.45mm x 17mm x the length needed as calculated. I would think the 0.45mm / 18 thou would be too strong for the Going train ?
    Kind Regards,
  4. Bruce Alexander
    Donor Sponsor NAWCC Brass Member
    Feb 22, 2010
    5,954
    348
