Ordering a second hand
Bob P.
Nov 12, 2008
23
S.E. Pennsylvania
Hello all,
This is the first time I've had to order a second hand.
Merritt's and Timesavers list the hand length and mounting
post length and even if the mounting post is slotted, but not
the size of the hole to fit on the seconds bit. Do they go by the
type of clock the hand is listed for, or is there a standard size?
Thanks,
Bob
The Tick Doc
Dec 30, 2007
204
70
South east USA
hello Bob. In regard to the id of the pipes , are they too small or too wide? The last one I used did not fit on the seconds post. The hand was not secured to the pipe very well and the pipe was too small. I was able to remove the hand ,chuck the pipe in my lathe , bore it out some and reatach the hand .This worked well fore me, maby this eill help you out some. ... good luck....Keep us informed................TTD
Scottie-TX
Apr 6, 2004
936
61
80
Mesquite, TX
Yeah, for me replacing a subsidiary seconds hand has always been a crapshoot. I've even bought several in hopes of a near fit. No - as usual, nothing here is standard. Best you can hope for is hole being too small which for me, most often was too large.
Bob P.
Nov 12, 2008
23
S.E. Pennsylvania
Thanks TTD, The hand is missing. I am able to modify a mounting post as you have done if need be. The seconds bit is .030 and I'd like to avoid getting a post with a hole larger than that. It would just be a little easier
that way.
Bob
-> posts merged by system <-
Thanks Scottie, Your experience is what I thought would happen.
The hands I think I can use are inexpensive enough. I'll buy two or
three different ones and plan on a modification.
Bob
14,078
1,503
Yes, just keep accumulating them ... they're pretty cheap and the bigger the assortment on hand the better the chance of a fit on the next job. :)
Best way I have found to 'shrink' the tube is with a dull pair of big wire nippers. Same ones I use to shrink German minute hand cannons / friction clutch. A dull center punch against a lead block is good too Be sure to do this at about half way the used part of the tube.
166,205
1,448,055
86,729
SeaChest
2,882
