Opening Sandoz
Discussion in 'Watch Repair' started by mentat247, Apr 30, 2009.
  1. mentat247
    mentat247 Registered User
    Apr 19, 2009
    19
    Chicago
    I am trying to open a Sandoz Singapore Day Date 40mm. I measured the back at 29.5mm and tried to use a HEDAPAI No 5537 tool to open without any luck. I thought this watch opened with a rolex tool? Has anyone worked on these and can advise me?
  2. doug sinclair
    doug sinclair Registered User
    Aug 27, 2000
    14,364
    50
    Calgary, Alberta
    What are the chances that this is a press fit style of back? Much like Swiss Army. LOOKS like a screw back, but is a snap on.
    Doug
  3. Rick Alhadeff
    Rick Alhadeff Registered User
    Feb 11, 2004
    101
    watch/clock service/repair
    Honolulu
    I second Dougs opinion - willing to bet it snaps on. Try it carefully. What happend when you tried with the 5537 tool? Did the tool slip or not move at all? Aloha, Rick:cool:
  4. mentat247
    Apr 19, 2009
    19
    Chicago
    The tool didn't fit...it was too small. If it is a snap on, how would I remove it?
  5. le arsi
    le arsi Registered User
    Jul 7, 2008
    461
    Watchmaker,tower clockmaker, watch repair teacher/
    Philippines
    Try to look at the toothed back case it is sharp and deeper and perfectly angled, than the Swiss Army so I recommend a three prong universal case opener to fit it.
  6. mentat247
    Apr 19, 2009
    19
    Chicago
    so you think it screws off?
  7. Jon Hansen
    Jon Hansen Registered User
    Dec 19, 2005
    23
    Maybe it does screw off, but it might be a snap on. Jon Hansen
  8. John Weigel
    John Weigel Registered User
    Apr 17, 2005
    66
    ER MD
    N California
    Call Sandoz?
  9. mentat247
    Apr 19, 2009
    19
    Chicago
    Its a screw back
  10. mentat247
    Apr 19, 2009
    19
    Chicago
    I got a universal case opener but the teeth are so small it slips! I can't get the thing open!
  11. le arsi
    Jul 7, 2008
    461
    Philippines
    Try to improvise. Use a large nut that will almost cover the entire back and glue it with cyanoacrylic (superglue) then let it dry (really dry). Then turn the nut slowly with your vise to open it. Good luck!
  12. doug sinclair
    Aug 27, 2000
    14,364
    50
    Calgary, Alberta
    le arsi,
    That trick might work with a solid steel back, but what is your opinion on the advisability of trying it with a glass backed watch, where the glass is held in with a neoprene ring? If the owner was real serious about getting the case back off, he'd have sought help, other than on this MB. In fact, somone with some tools and experience in such matters. IMHO.
    Doug S.
  13. mentat247
    Apr 19, 2009
    19
    Chicago
    The largest rolex bit I have is 29.5...perhaps I can find a larger one.
  14. le arsi
    Jul 7, 2008
    461
    Philippines
    Yes Doug I forgot to tell not to expose the glass ring into superglue , sorry. What I'm referring to is the metal part after the glass. A large nut might do the trick. But I'm just thinking, I've opened plenty of this model and I just used 2 and 3 prong opener with the help of a case vise and a very confident grip.
  15. mentat247
    Apr 19, 2009
    19
    Chicago
    Please click one of the Quick Reply icons in the posts above to activate Quick Reply.
  16. mentat247
    Apr 19, 2009
    19
    Chicago
    Maybe my universal opener is cheap cause the bits slip on the teeth of the caseback. As for the "rolex tool" I have the 5537 kit but that doesn't come with a bit large enough.do they even make a 30+ nut?
    With this glue idea, once you get the case open how do you get the glue off?
    Noob question: which way do I turn the caseback to unscrew it? Counterclockwise?
  17. le arsi
    Jul 7, 2008
    461
    Philippines
    You can remove the glue with an acetone. And to unscrew a back case turn it countercw of course. If you are not sure with your self, try doing it in another watch case with tight back before applying it to Sandoz. This is to make sure you have the idea. You're making me nervous! :)
  18. mentat247
    Apr 19, 2009
    19
    Chicago
    Tried the super glue, my vise started to bend! Then the glue failed, this thing is really on tight! Argh!
  19. mentat247
    Apr 19, 2009
    19
    Chicago
    I think my problem is my vise. The holding pegs give before the caseback. What vise do you all use? They seem to be at any and all price ranges.
  20. le arsi
    Jul 7, 2008
    461
    Philippines
    Can you post a pic of your vise?
  21. mentat247
    Apr 19, 2009
    19
    Chicago
    Attached is a picture of my vise and a detailed shot of the "flex damage" it recieved under pressure.
    Another note on the superglue, the acetone took it off the crystal easy, but it did not come off the metal easily. The caseback got scratched getting it off. I don't care much about the caseback, I just want to open the thing.
  22. le arsi
    Jul 7, 2008
    461
    Philippines
    The kind of vise you have is not good it really slips, try to remove the bracelet and the head link and place the pegs in between the case linker. If still it doesnt move at all. Take a discarded screw driver or knife place the blade on the sides of the back case then apply few taps ( Doug might be right the case is a snap back) if it shows some movement then continue to tap more.
  23. mentat247
    Apr 19, 2009
    19
    Chicago
    I opened it! Actually the rolex 29.5 tools worked, the vise was the problem got a table vise that was much more stable. Now I can send the dial off to international for refinishing.
    Thanks for all your help.
  24. le arsi
    Jul 7, 2008
    461
    Philippines
    Here is my long time use no slip case vise. It's made from carabao horn.
