Opening case on a late model Hamilton 505
Discussion in 'Wrist Watches' started by czach, Apr 6, 2017.
  1. czach
    czach Registered User
    Jul 28, 2009
    435
    This is interesting. I picked up (another) Hamilton 505 on Ebay, and I don't see how one opens the case.
    Doesn't appear to be a crease in the back, doesn't have the case opener pads like a Titan, doesn't open like a Savitar. How do you get the movement out?
    PS: It works, so someone must have replaced the battery but the PO forgets, maybe the crystal.
    Thanks!
    C
    [​IMG] [​IMG]
  2. roughbarked
    roughbarked Registered User
    Dec 2, 2016
    1,917
    watchmaker
    Western NSW, Australia
    Looks to come out from under the glass. Try pulling the crown out to the hand set position and give it an experimental further pull. If the stem is a split two piece stem it should come apart. If this does happen and please don't break the stem if it doesn't come apart easily, then you can use the air pressure from a syringe to blow the glass off.
  3. czach
    Jul 28, 2009
    435
    Hm, pulled the stem, it doesn't feel like it wants to come out further (don't want to break the stem setting screw) and it looks to be a similar stem to my 505 RR special (also same larger hands, etc). Hm.....
  4. roughbarked
    Dec 2, 2016
    1,917
    watchmaker
    #4 roughbarked, Apr 6, 2017
    OK, do you have the glass removing tool that grabs all the way around the glass? https://www.youtube.com/watch?v=yu9igPfhzbM
    Does the glass have a tension ring around inside the glass? If So then simply fit the tool to the glass and hold it rather than squeeze it and slip a case opening knife under the tool and twist it so that it lifts the glass out.
    If it doesn't have a tension ring you can squeeze the glass slightly with the tool and it will lift out.
  5. czach
    Jul 28, 2009
    435
    Nope, but it looks like I'm going to be buying one from ebay. $15 tool ok or should I get the $120 Bergeon one?
  6. roughbarked
    Dec 2, 2016
    1,917
    watchmaker
    The Bergeon one will last forever but there aren't many watches made these days that require them so if the $15 unit looks to function the same way, it should do the job once.
    If the case is a one piece case, the stem still has to come out somehow. If it isn't a split stem with male female connection then there should be a visible place to press the set lever or lift it, so that the stem can be removed but this probably cannot be seen until the glass is removed. Often if this is the case, after removing the stem, turn the movement in an arc until it can fall out if tipped upside down.
  7. czach
    Jul 28, 2009
    435
    Indeed. I use Bergeon screwdrivers because they never fail me with galled heads or slipping, and I use bergeon oilers for same reason. This though will be a one time thing, so I'll try the Ebay special.
    And this 505 runs slow. Which means a worn contact, need to see if it's possible to swap those....
  8. czach
    Jul 28, 2009
    435
    Got one. Pretty simple actually, crank down, then quarter turn till crystal comes out. I assume you don't leave the crystal compressed in it for awhile, I've just been removing the movement, then putting the crystal in the empty case. Keeps dust out.
    Now to figure out why this presentation watch is not working. Different problem :)
Similar Threads - Opening case late Forum Date
Omega Deville opening issues. Wrist Watches Sep 2, 2014
Trouble Opening a Seiko Hi-Beat 23 Jewel watch 2409-0019 Wrist Watches May 2, 2014
Illinios wristwatch case opening question Wrist Watches Feb 14, 2014
opening case on Seamaster Wrist Watches Jun 9, 2006
