Once Again: How to Re-do movement lettering?
Discussion in 'Watch Repair' started by Michael Maddan, Apr 1, 2017.
  1. Michael Maddan
    Michael Maddan Registered User
    May 24, 2015
    50
    I apologize if I missed an earlier Post that answered this question...I only found one, and it suggested a fine-tipped magic marker. Isn't there a better way? I enjoyed a very nice Swiss factory video recently, and the technique clearly shown to fill the movement's engraving (with red), was to run in a very watery-looking solution...the video did not show subsequent operations, but, I assume that the excess was ( very gently!) mechanically buffed away.
    So: how do the Restorers among us do this? As always: Thanks! Michael.
  2. Mark UK
    Mark UK Registered User
    Apr 13, 2015
    268
    Lincs, UK
    I am sure you will get a varied response but I use artists acrylic paint (matt black) and a fine tip brush. I go over the lettering quite quickly, you don't have to be that carefull about excess paint, leave to air dry for a minute, then with a very lightly damp cotton cloth I wipe away the excess, you could use a dry cloth if you are worried about getting any moisture on the plate. I then leave a further 5 minutes for acrylic to harden a little more then gently buff with a clean soft cotton cloth. I know that others use similar technique but with enamel paint and spirit to clean off excess. I prefer acrylic because it is quick to dry and has little mess. I am sure that enamel will withstand subsequent cleaning far better than acrylic but if the paint does come away after an ultrasonic clean then it is simple enough to reapply. The final result is pleasing to the eye and the matt black reflects just enough light to match the original black used at manufacture.
  3. karlmansson
    karlmansson Registered User
    Apr 20, 2013
    1,966
    Doctor
    Linköping, Sweden
    I think you are looking for engravers ink. Engravers today use markers to some extent but you can dilute a paint or pen ink to your preferred viscosity and then wipe in on. Then you wipe off the excess with a clean wipe.
    If you google "engraving ink" I'm sure you'll find loads of suggestions. Theres also the dial wax method with a dyed shellac that you melt in, scrape off and melt again to make it shiny.
  4. Paul_S
    Paul_S Registered User
    Mar 27, 2015
    154
    These are all good suggestions. I have had good luck with enamel paint and a fine brush, and denatured alcohol to remove the excess. It will survive the cleaning machine well afterward.
  5. Michael Maddan
    May 24, 2015
    50
    Thanks, everyone! I appreciate the Comments, and will run a few experiments over the next several days, & see what works for me.
    Michael.
Similar Threads - Once Again movement Forum Date
Here I go Again:-4992B to fix Watch Repair Sep 26, 2017
making a balance staff,,best way all at once or flip around to finish.... Watch Repair Sep 20, 2012
Knocking, AGAIN! Watch Repair Sep 9, 2012
Electric WW L & R Lives Again Watch Repair Apr 2, 2012
English PW fusee chain broke again Watch Repair Oct 3, 2011
