Hi,
I recently looked into my Speedmaster 125. Upon unscrewing the back I found a black goo, which apparently had been a seal long time ago. Quite a mess to remove, but I managed.
Now I am wondering about a correct seal. It should be 35 mm, but with what cross section and cross section dimensions? Seals may be of round or square cross section. The material should not be all too critical, since the watch will anyway not be exposed to water.
Strangely I find nothing using Google (or I am searching wrong). Since the 125 case is quite different from the "normal" Speedmasters, it might be that the seal is not the same?
Cheers, Bernhard
Cheers, Bernhard
