Hi MartyR,
what I wrote above is no real surprise. If a company is just one year old,
it simply can't have ten years old stock. So if they make or buy movements
and cases in about the same quantities, serial numbers will not differ much.
Later it can well happen that a particular case or movement lies pretty
long on the shelf, and accordingly the serial numbers may differ.
For instance there is a good reason to use a gold case as soon as it is
ready. So gold cases are often younger than the movement inside, and
therfore have a higher number.
Or imagine a very high grade movement. It costs the manufacturer not
much more than its simple counterpart, but it as not so easy to sell. So
the shelf time for such miovement is often longer than for its case.
Moreover Omega sold bare movements, and nobody knows whether they
made according gaps in case numbering.
However, in any particular case one may imagine why there is a difference,
but you'll never find out the actual reason.
Regards, Roland Ranfft
