Omega fob watch mainspring....help needed to choose replacement :-(
Discussion in 'Watch Repair' started by PJQL, Apr 4, 2017.
  1. PJQL
    PJQL Registered User
    Jun 13, 2011
    1,248
    Retired police officer
    Cornwall UK
    Hi all,
    Could anyone offer some assistance in helping me choose/identify a replacement mainspring
    for this Omega fob watch please?
    What type or reference numbers should I be looking for when choosing the correct replacement ?
    The barrel width is about 1.1cm, and the width of the existing broken mainspring is about 1.1mm.
    There are no helpful numbers etched or stamped into the barrel anywhere.
    Any help would be much appreciated .
    Regards
    Piers
  2. Skutt50
    Skutt50 Registered User
    Mar 14, 2008
    2,898
    Gothenburg
    Is this a small pocket watch?
    I usually measure the length, width and thickness of the existing (broken) spring and look for one that is the same.
    The original springs are made of blue steel but today you find white "unbreakable" springs which are a tiny bit harder. When replaceing a blue steel spring with a white steel spring you can go down a hundred or two mm in the thickness of the spring.
    On old Omegas you also need to check which type of attachment there is in the barrel. Some are of a T-type and some folded at the end. (Some barrels can take both! Could be later adjustments!) You seem to have the folded type!
  3. PJQL
    Jun 13, 2011
    1,248
    Cornwall UK
    Hi Skutt50,
    Thanks for that :)
    Yes..its a 29mm diameter movement. When I'm looking on the internet, all the replacement springs seem to have reference numbers etc....so it's a bit confusing. I think it would help if I knew the calibre number.
    Piers
  4. PJQL
    Jun 13, 2011
    1,248
    Cornwall UK
    Hi,
    Anyone know the likely calibre for this one?
    Piers
  5. Albert Antonelli
    Albert Antonelli Registered User
    Jan 8, 2011
    185
    I agree with Skut, you measure the width, length, and strength of the spring, the only other way would be by finger printing the setting bridge and set lever if you have a parts catalog that is old enough to have that information. My two cents worth, good luck.
  6. Skutt50
    Mar 14, 2008
    2,898
    Gothenburg
    On modern Omegas (wrist watches) the caliber is stamped on a plate visable from the back but on some older movements you can find information stamped on the main plate, under the balance wheel.
    You could also go through these pages to search for the caliber:
    http://www.ranfft.de/cgi-bin/bidfun-db.cgi?10&ranfft&2&2uswk
    You can limit your search by starting with the size of the movement.
  7. MrRoundel
    MrRoundel Registered User
    Dec 28, 2010
    854
    So. Cal., USA
    The big Swartchild catalog from 1951 has a very good section on mainsprings. It shows width as the primary measurement. You then look down the column to find the strength/thickness and length. It's under the Black Shield brand section of mainsprings with a tongue end. But again, you'll need that to provide the thickness, either in Dennison or metric, as well as the length of the spring. With that info someone should be able to find you a part number that will work. Do you have a mainspring gauge or micrometer to take the thickness measurement?
  8. PJQL
    Jun 13, 2011
    1,248
    Cornwall UK
    Thank you Mr Roundel...appreciated.
    Unfortunately my toolkit is very small, and needs a serious upgrade! Your input is very welcome though:)
    Regards
    Piers
  9. MrRoundel
    Dec 28, 2010
    854
    So. Cal., USA
    YW, PJQL. You might try looking for a relatively inexpensive mainspring gauge. It's the one that looks like a 6" ruler made of brass that has sized notches in the sides for measuring width, and a tapered opening slide for measuring thickness. I'll bet Dave's Watch Parts has one for sale. Ah yes, go to WT602 on the link below, and you'll see the tool of which I speak. You should be able to find one on your side of The Pond as well. Good luck.
    http://daveswatchparts.com/Measuring.html
  10. Skutt50
    Mar 14, 2008
    2,898
    Gothenburg
    Did you mean WT2602?
  11. MrRoundel
    Dec 28, 2010
    854
    So. Cal., USA
    Probably. I went by memory, and that can be a mistake. Thanks for the correction.
  12. roughbarked
    roughbarked Registered User
    Dec 2, 2016
    1,917
    watchmaker
    Western NSW, Australia
    Digital vernier calipers could get you close.
Similar Threads - Omega watch mainspring Forum Date
Omega pocket watch in need of jewels Watch Repair Jan 27, 2017
Mechanical WW How do I find/fit Omega wrist watch glass Watch Repair Jan 30, 2016
Help- My watch movement came in the wrong case! (Omega Constellation) Watch Repair May 31, 2015
Mechanical WW Omega Watch mainspring help Watch Repair Jun 20, 2014
Mechanical WW Omega ID and mainspring help (pocket watch) Watch Repair Jan 9, 2012
