Omega 200m
Dwayne
Mar 25, 2010
Have an Omega 200m automatic movement watch that will not wind with stem or rotor. Any thoughts on the probable cause?
Dave Haynes
Sep 12, 2000
1,478
84
Sometimes the clutch lever or its spring slips off the clutch wheel and the clutch fails to mesh with the winding pinion making hand winding impossible. Or the winding pinion is put in backwards and has no teeth to mesh with the clutch.
John Runciman
Aug 13, 2003
618
144
Seattle, WA
Always hard to do watch repair by guessing even if it is a really good educated guess.
Then it's always helpful have information like how old is the watch, when was the last time it was serviced or has it had any problems prior to this problem? Then not always thought of as a problem but it's definitely a problem as the watch ever got moisture inside it's amazing how bad rust can be.
Then unfortunately we have to generalize because that's a pretty generic term? Pictures may be but even then we can't see the movement serial numbered be helpful we might Be able to look that up.
agemo
Apr 5, 2011
571
593
93
72
SAINT-NAZAIRE - FRANCE
Hi,
Why not simply mention the breakage of the barrel spring ?
Amicalement GG
Reactions: John Runciman
DeweyC
Feb 5, 2007
2,745
1,356
Baltimore
www.historictimekeepers.com
Hi,
Amicalement GG
I think John's comment has value. It is useful to obtain additional info before attempting a diagnosis.
Did this just happen or is this the state in which it was received? If it is the state in which it was received, and since the OP apparently does not have repair expertise, it may be a question about returning the watch.
If this is a watch he used for a while, then the question would seem more a matter of curiosity. I gave this model to my daughter and I consider a nice watch. It needs and "deserves" service.
175,197
1,532,286
52,613
RCBW
1,063
2,972
