Omega 18 ligne vs. 19 ligne -- staff information.
MrRoundel
Dec 28, 2010
1,370
253
So. Cal., USA
Does anyone out there know if an early 18 ligne Omega might share a staff with the 19 ligne? I have a pre-1900 model that has a bent balance pivot and it may well snap when someone tries to straighten it. The length measures 5.93mm, but may be 5.95mm with a straight pivot. Any help is appreciated.
Note: eri231 posted a page from an Omega book that showed the 19 ligne movement, as well as others. If he has a similar page that shows an 18 ligne, I'd really appreciate seeing it. Maybe there's no difference aside from the plate sizes? My watch movement is pictured. Many thanks, and Happy New Year, all. attachment.jpg
eri231
Jan 13, 2012
1,580
472
torino italy
hello
maybe this one?
regards enrico
MrRoundel
Dec 28, 2010
1,370
253
So. Cal., USA
I've got to take some other measurements, but I suspect that it is the right part. I am in your debt, Enrico. Thank you very much. It seems that you possess rare information and knowledge of these watches. Thank you for sharing the book pages. The NAWCC MB is lucky to have you as a participant. Thanks again. Have a great 2014.
Enrico, or anyone else, do you happen to have any comments regarding the scarcity of the 18L? The one in my possession is a private-label for a New York jeweler, known for having sold high-grade timepieces.
MrRoundel
Dec 28, 2010
1,370
253
So. Cal., USA
I'm now wondering if my Omega is a 40.6? This would stand to reason, as the dial diameter in millimeters is right there. The plate configuration matches, however, the setting mechanism is all 19NN. Also, in checking the Bestfit catalog system's numbers, their staff #599 seems like it offers measurements could possibly be worked with. They also have a designation of "D62" as the caliber/model, where the balancestaffs.com listing shows a "062". Coincidence? Finding the right antique watch parts can be quite challenging, can't it?
My main objective is to be sure that I can find the correct staff for the watch before I try to straighten the bent pivot. I'm trying to avoid paying a real watchmaker to do it for me, as that would cut into the benefit of my bargain on the watch. At the same time, I don't want to risk messing up what might be a rather rare movement. As usual, it's a tough call for me.
MrRoundel
Dec 28, 2010
1,370
253
So. Cal., USA
Update: I got lucky and the pivot straightened out pretty nicely with the hot tweezer treatment. I kept trying and suddenly, to my surprise, it became nearly perfectly straight. However this was not before burning my thumb on the hot tweezers. For the subsequent attempts, I held pithwood buttons on both sides, making a tweezer sandwich. Much better. It's running like a champ now. This good because the Omega staff (4169) it may have been, wasn't it. The tolerances are very tight on this watch. It was even a bear to get the upper plate to set on the pivots. I had to use the screws to tighten it down while I maneuvered everything in place. That was nerve-wracking. Then there was the trying to find a suitable mainspring, which I eventually did. All's well that ends well.
Latest posts
165,505
1,440,731
86,272
Lkleinow
2,873
