Older regula 1 day
POWERSTROKE
Jan 11, 2011
1,252
81
This is in a heco. I’ve not removed the movement yet. One problem is the door opens and closes when it’s cuckooing. This is the type of regula where the perch is held out by the lever on the side. Not the flag like on the newer ones. Any quick tips how to keep the door open on this one?
JimmyOz
Feb 21, 2008
851
185
65
Gold Coast Qld
A photo would be good.
I sounds like a count wheel on the back plate, if so, look at the lever when it falls, it should just clear the the rim of the count wheel and then fall into the slot at the end of the count. If the lever is to high it allows the other arm of that lever to fall into the cam on the inside of the movement thus allowing the cuckoo bird to retract and open again instead of just at the end of the count.
JimmyOz
Feb 21, 2008
851
185
65
Gold Coast Qld
Okay not a count wheel.
Not sure on this one as I have never worked on that movement, someone should know though just wait and see.
POWERSTROKE
Jan 11, 2011
1,252
81
Can anyone tell me what the adjustment is to get the perch to lock in that upper hook? The problem is the perch isn’t getting pulled far enough forward.
14,051
1,494
Well it can only be two things:
Either the perch throw is to short, the catch wire (top) is not quite reaching the latch point. This is adjusted by bending the black stamped lever that's sticking out to the lower right side of your photo.
Or, the latch is faulty. This can be due to wear but is often because the hook is not free enough to move as quickly as it should. IOWs it's gooped up with old oil, hair, lint, carpet fiber, dust, juice from various insects, you know.
disciple_dan
Mar 10, 2016
995
81
Plant City
English: gooped up
Definition of 'gooped up'
gooped up in British English
(ɡuːpt)
ADJECTIVE
sticky with goop
Collins English Dictionary. Copyright © HarperCollins Publishers
It's ok to say "gooped up" Isn't it? I never thought about it but I have probably used it my whole life. Interesting.
Just fun'in here, not arguing. Have a great day, Danny
Reactions: roughbarked
166,141
1,447,323
86,684
ds23pallas
2,883
