Older Clock Parts Wanted Posts
DJ Ritchie
New Member
Jan 4, 2019
Derek Smith. I see this is an old post, but I am new to this forum. Did you find the silencing lever for your Hermle clock? I have one if you’re still interested.
etmb61
Oct 25, 2010
2,859
295
Mascoutah, IL
Hi Derek,
The chime silence lever for Hermle is on the front of the movement and stops the operation of the chime train. The hammer lever shown is only for transporting the clock.
You might have better luck in the clock repair forum.
Eric
bangster
19,988
513
Eric: DJ's thing is what's circled in derek's photo.
MillTime
Jan 12, 2009
141
Hello, I am looking for the escape wheel and arbor in good condition to a Waterbury T&S strike clock. It is a common movement, with the escapement outside of the plates. The plate says "13in", the escape wheel has 37 teeth, with a 32.8 diameter escape wheel. The lantern pinion (located close to the back plate) has 8 leaves, and the arbor is approximately 47.4mm pivot end to pivot end. Thanks for any help!
46,950
1,996
Check with LaBounty, MillTime. He has a huge inventory of used parts, and could even make the wheel for you if needed.
Vincent Goggins
New Member
Jan 13, 2019
Looking for a JJ. Elliott Hall - Grandmothers Movement only - Pendulum 33” Where or who could I reach out to? My clock is very Sick!
Any Help would be Terrific
Vince
Armando Alcaraz
Sep 4, 2018
45
55
Greetings to all!! I am in need of parts or a replacement mantel clock round Seth Thomas 48L movement. I need a escapement and arbor as well as case screws and retainer arms and hardware. Or if someone has a "For Parts" unit, I could consider that as well.
Thank you for your assistance!!
20190114_234406.jpg 20190114_234414.jpg 20190114_234434.jpg Screenshot_20190115-000011_Gallery.jpg Screenshot_20190115-000130_Gallery.jpg
46,950
1,996
Vince
Welcome to the board, Vince! You might try your inquiry in the clock repair forum. I'm sure it can be restored, if not by you then by a professional. It's very hard to find movements like you are seeking.
Tony P
New Member
Jan 24, 2019
Hi
Looking for a square convex clock glass that fits bezel for Junghans clock. Measures 5.75 inches inside track to track so a glass 5 5/8 to 5 11/16 would fit. Rise is 1/2 inch from face. Bezel has two channels but would use outside channel to install. Thanks !!
Tony P
Hi Tony...
Welcome to the Message Board!
I've moved your request to the forum it belongs in.
bangster
Heidi2015
Nov 22, 2015
Hello, I am in need of a new escapement gear for this clock. It is 43mm in diameter with 50 teeth. Unfortunately there is no manufacturer information anywhere on the movement. Any help is appreciated.
bangster
19,988
513
Show us a pic of the whole clock, Heidi. That will help.
KarynC
Oct 4, 2017
View attachment 512467 View attachment 512468 View attachment 512469 View attachment 512471 View attachment 512472
I have a complete movement with dial, pendulum and gong. It is a 48S-it would probably work. I will post photos if you are interested-I'm home now and the clock is at work so tomorrow evening at the earliest.
Higgins
New Member
Jan 25, 2019
My husband wants to repair a Square Oak Slave School Clock 1887. He believes the spring is wind to tight. And there is a light on the front, bulb looks like the one that went in a flashlight. Where would I be able to get information on this clock?
46,950
1,996
If it's a slave clock, it would not be wound but would work electronically, governed by a separate master clock. You can buy impulsers to make it functional though. Lets see a pic of the clock please.
Solomon Wilharm
New Member
Feb 4, 2019
I have recently acquired a nice Hamilton-Elgin 37500 elapsed time clock. I am planning to do a service for it, but I see a couple initial parts I would like to buy. I noticed that the clock had two hands replaced at some point in its life - the hand for the hour portion of the chronometer (top dial) and the hand for the civil date function. Does anyone have the correct hands available for purchase? I appreciate all the help.
Solomon
Heidi2015
Nov 22, 2015
There is a tag that says "manufactured by International Business machines" inside the case, not sure if that is the movement too, or just the case.
bangster
19,988
513
I am really most sincerely in need of a Seth Thomas electric motor like this one, except for two wires instead of one.
Eight-leaf pinion. 120v 60hz
46,950
1,996
When I get on my other computer later today, I'll try to find that repairman for you.
167,112
1,456,240
87,316
Clockman1965
