Most visitors online was 1660 , on 12 Dec 2020
Well I am taking over a repair so no bushing but the gear on the main shaft was replaced, I have the movement apart and just the time side in when power is applied you can't move the minute shaft at all. Time for thinking. Without power the 4 gears spin as they should.I see a circle around a bushing. Has this been serviced? The rope cable is over lapped on the drums too. Can you give us some more information or possibly a video.
Not switched, I am looking at the stiff brass tension washer and a bent hour bridge as I tighten the screws on the hour bridge and put the 4 post pins it becomes difficult to turn the train with thumb pressure on the time main wheel.t1 and s1 switched?
