Old Gilbert mirror side. Help
wow
Jun 24, 2008
5,432
613
76
Pineville, La. (central La.)
Got in this one with a strange fly that is missing something. Looks almost like a 70’s Korean movement fly with the cup on one end. Never had this movement before. Patent 1884. Somebody tell me what the fly is supposed to look like please.
4C4B52D4-B3E0-4097-8CF1-0622A22982A4.jpeg 4103FC3D-25C8-4175-9F91-67FB5F65E5B2.jpeg AD565D3E-87C0-4283-887A-7F2778A87ABC.jpeg 52404C2B-FE61-4FDA-961B-77A8E82B3018.jpeg 71F29B77-0DEA-4C52-8793-50E30B35956B.jpeg 3378952E-641C-4292-BD84-D5FDF944FF59.jpeg
14,776
1,741
I don't know of a good way of repairing the old brake mechanism. I remove the old drum and use a regular fly. This will work fine but you will need a fly that occupies all of the available space.
Reactions: Jaap
wow
Jun 24, 2008
5,432
613
76
John Arrowood
NAWCC Gold Member
Dec 14, 2001
820
218
The Gilbert fly worked as a centrifugal governor; as the strike train started running two shoes with leather on one side spread out and rubbed against the sides of the cup and regulated the speed of the fly. I ruined mine by putting the fly in an ammoniated cleaning solution which destroyed the leather in a couple seconds or less.
wow
Jun 24, 2008
5,432
613
76
Thanks, John. Yep, the Koreans must have copied it. Their shoes are made of plastic and tear up easily. I have one in my shop that has a black rubber thingamajig inside the cup that is split and expands with centrifugal force braking the arbor. When it gets old, however, it gets brittle and does not expand. Junk!
wow
Jun 24, 2008
5,432
613
76
Well, here’s what I did. Decided to keep the cup and make a fly that extends inside the cup. I used the original arbor. It works fine. A little fast, but many of the older clocks had fast strike trains, so it should be ok. The filthy movement cleaned up well. Actually very little wear. Only four bushings needed.
F0CC6B9E-EED6-4BB4-9859-BDD844609B3A.jpeg B460A531-277F-4645-8776-8A5CD3816205.jpeg 7E1D4B95-09C4-47B8-8681-FB6034DD206F.jpeg
14,776
1,741
If you loose the little drum, you can add a little more fly. Even with max surface area it will still a little fast. I just back off on the windup a bit.
Next one I do, I'm going to experiment with little spring arms running in line with the arbor.
wow
Jun 24, 2008
5,432
613
76
Hey, I like that idea, Willie. The stops are still on the clock and the springs look like original heavy strong springs. I’m gonna try setting the stop at about 3/4 wound and see what happens. I hate to do away with the cup since it was part of the original patent and rare. Who knows…… some ambitious repairman may want to try and make the little brakes 50 years or so from now when I’m long gone.
wow
Jun 24, 2008
5,432
613
76
Can you tighten up the springy part? It might slow down some. Most Korean clocks I have repaired tend to keep very good time. They certainly are not a great quality.
Thomas, the springy parts inside the cup are missing. Is that what you are talking about? I thought about using some from a Korean movement but opted for the fan only. Actually it is not much faster than most old American movements. I’ll try the stop set thing and see what happens.
47,369
2,131
I wonder if parts of a watch mainspring might provide enough braking action against the sides of the can?
Thomas Sanguigni
Aug 22, 2018
432
112
secondhandclockshop.com
Will, I meant the spring that the arbor passes through. Push it down a bit more. It may help to slow the fan during operation. Try to reduce the slip on the spring. I worked on a ST hip movement once. The previous owner wanted a slower strike. They bent the tips of the fan inward to catch more air. The fan on a hip movement is larger, but more friction will slow your strike. I restored the hip movement fan to its original condition.
wow
Jun 24, 2008
5,432
613
76
Upgrade: I just didn’t like the rapid strike so I made two little brakes and added them to the fly inside the cup. The centrifugal force created by the fly turning causes the little plastic balls to brake on the drum. Kinda like old time drum brakes. Slowed it down perfectly.
4C2CC8DA-171A-4EB7-802D-104A8DA777F1.jpeg 77DDB7CA-9123-4A98-B6D3-B4826EF8640F.jpeg
Reactions: shutterbug
wow
Jun 24, 2008
5,432
613
76
Very interesting Will! It looks like an item in clock vendor's catalog. Can you post a video of that?
Thomas, I already have it back in the clock. If I have to remove the movement for some reason I will make a video. It is very much like the patent posted by Steven above and I have worked on several Korean movements that had a brake similar to mine without a fly.
Will
168,195
1,466,874
48,160
HIltonD
2,955
