Old GHS Cuckoo-Quail Weights
Discussion in 'Clock Repair' started by MuensterMann, Apr 11, 2017.
  1. MuensterMann
    MuensterMann Registered User
    Mar 23, 2008
    891
    I recently picked up a circa 1900 GHS cuckoo-quail clock. It came with two 1250g weights that were the same, and a third weight significantly more. I verified that it is a one-day clock. Usually such weights are affiliated with 8-day weights. I imagine that the two lower weights are not original to the clock. Does anyone know what size weights were original to such a clock?
  2. Willie X
    Willie X Registered User
    8,065
    29
    Often around 800 to 1000 gms.
  3. MuensterMann
    Mar 23, 2008
    891
    Wow, still an awful large amount of weight for a one day! Thanks Willie for the input!
  4. shutterbug
    34,330
    All three weights on mine are 3.2 pounds each.
  5. MuensterMann
    Mar 23, 2008
    891
    Wow! Okay, 1451 grams each!! Perhaps the 1250g weights on mine are the original ones (well, the two of the three). Shutterbug, is yours a GHS clock as well and do you believe your weights are original?
  6. dAz57
    dAz57 Registered User
    Dec 7, 2011
    1,880
    7
    watchmaker
    sydney Australia
    I have a GHS 8 Day cuckoo and it runs a pair of 3.5kilo pinecone weights, try to run lighter weights and it doesn't like it, so it sounds like your weights are about right.
  7. shutterbug
    34,330
    I'm not sure, Muenster. It's an old one though :)
  8. MuensterMann
    Mar 23, 2008
    891
    Here is a photo of this cuckoo quail. The movement has pins to hold the plates. Any information on this clock - such as the age? I know that it is probably somewhere between 1890 and 1910. Also, here is a photo of one of the two weights that are the same. It has a 2 1/2 on it, probably for 2.5 pounds (1133g), although the weights weight about 1210 and 1260g.
    [​IMG][​IMG]
  9. ballistarius
    ballistarius Registered User
    Oct 26, 2009
    702
    Architect
    Bilbao, Basque Country
    Muenster, your clock appears as model 4083 on the GHS 1905 catalogue. Of course, the production of the model could start earlier than that.
    Aitor
  10. shutterbug
    34,330
    Same mark as on my weight (only one has a mark). Yes, 1905 sounds real close.
  11. MuensterMann
    Mar 23, 2008
    891
    Thanks all for the information!
  12. ballistarius
    Oct 26, 2009
    702
    Architect
    My pleasure!:D
    BTW, is the model number '4083' handwritten on the backboard of your clock?
    Aitor
  13. MuensterMann
    Mar 23, 2008
    891
    I looked at the back door, inside and outside and didn't find any model number. I looked inside the clock as well and didn't see any number. The only writings I find on the back door are dates of service in the 50s, 60s, and 70s and the name of the repairman.
  14. ballistarius
    Oct 26, 2009
    702
    Architect
    Many thanks:D
    I asked you because my GHS cuckoo has the model number handwritten on the backboard. Recently, another GHS cuckoo appeared on this MB and it too had the model number handwritten on the backboard. I was carrying some sort of informal survey...:rolleyes:
    Aitor
Similar Threads - Cuckoo Quail Weights Forum Date
Quail Cuckoo Help Clock Repair Aug 31, 2017
Quail cuckoo question Clock Repair Apr 30, 2017
Herr Cuckoo-Quail Hints Needed Clock Repair Jan 7, 2017
Welby Quail Cuckoo works photos needed. Clock Repair Jun 29, 2014
Quail / Cuckoo Bellows Clock Repair Jun 29, 2014
