• Upcoming updates
Before 1600 Old German thingy aka Türmchenuhr
DeanT
Mar 22, 2009
1,847
738
Australia
German gilt and engraved brass table clock
The case surmounted by the cast figure of a knight holding a spear on a steep concave top, each of the four sides of which is engraved with a winged cherubs head or a flower, on an open fret of pierced strapwork with a serpentine flat base, over four tapering columns set on each of the two removable side panels which are decorated with further strapwork, foliage and masks, the rear cover with two winding apertures set within a pattern of ribbands, foliage, swags, and - most unusually - incorporating a pair of hanging fish. The front panel with another pair of winged cherub's heads to the upper corners over swags of fruit and mythical term mounts, with pierced central aperture, all on a shallow spreading base.
The 2.5 inch silvered Roman and Arabic dial with alarm-setting subsidiary and pair of gilt brass hands.
The steel movement with tapering uprights, a pair of chain fusees, verge escapement and count wheel striking on a pair of bells mounted in the top section. 28cms (11ins) high
Photos and description thanks to Bonhams:
The clock is almost identical to a clock in the Warsaw museum apart from the engraving and later changes.
The top is similar design to Astronomical clocks in the British museum and Budapest museums although the tops are further embellished with wonderful mythical creatures and their movements are much more complex. The Budapest clock is dated 1577.
The fretwork design on the bonnet of the case is quite similar to the work of Nikolaus Lanz of Innsbruck in Maurice's book numbers 149 and 150 (150 is in the link attached). These clocks are slightly older around 1550's and often have similar plainer cases and simpler engraving.
It may not be a Lanz clock as he generally had two steps(?) on the square case pillars but if not its likely an associated maker around the same time.
The clock movement is often described as a metzger style movement who made many of the wonderful complex clocks of that era. They have three trains with the middle being perpendicular to the striking trains on the side. This requires much restoration but its a rare example of 3rd quarter 16thC clock.
zedric
Aug 8, 2012
2,157
555
Nice buy. If that could talk I bet it would have some tales to tell
novicetimekeeper
Jul 26, 2015
12,307
1,577
Dorset
It is very different to your other clocks in proportions, a good addition to the collection.
gmorse
14,837
3,934
Hi Dean,
I notice that the '2' numerals aren't in the usual Germanic 'Z' style, is this something that was just found in certain regions of Germany or is it date related?
Reactions: DeanT
P.Hageman
Jul 20, 2014
1,223
350
The Netherlands
Wooow, that an amazing early clock you bought!! You must have your own museum of real clock art. What a find again, congratulations Dean.
Reactions: DeanT
zedric
Aug 8, 2012
2,157
555
Hi Dean,
I think the dial is a "modern" replacement - well, more modern than the 1500s anyway
Reactions: DeanT and gmorse
DeanT
Mar 22, 2009
1,847
738
Australia
Hi Dean,
You're correct Graham the dial is replaced. Soon to be replaced in the correct style. Also note motion wheel work is in brass wheels are replaced when the dial was replaced. These will be replaced using bloom steel as well.
179,018
1,570,218
54,047
aztrukin
909
3,088
Swiss Fake by Kent
