Cuckoo Old Cuckoo Winding Repair or Replacement Part Help
expeditionhiker
Jan 4, 2017
66
hi, my old Regula has some type of spring wire wound around the shaft for the time winding sprocket/gear, it is broken so the chain moves in both directions freely. To get to it, a bushing and then the winding sprocket/gear was removed. I don't see or think there is any click to stop when winding, only this spring? It looks like the spring also acts as a bushing, maybe it expands inside to prevent the weight from dropping? Can this spring be replaced (where would I find one) or can I wind one, and how would I do this? thanks for any help
20221028_181443.jpg 20221028_182101.jpg 20221028_182108.jpg 20221028_183024.jpg 20221028_183106.jpg
18,667
3,988
The spring simply grips in one direction and slips in the other direction.
The springs were once available as a replacement part. AFAIK it will have to be made up now. Annealed piano, or piano wire worked hot, can be made to work. You will need a mandrel slightly smaller than the arbor to wind the new spring on and make sure you get the 'wrap' in the right direction. :)
Tbucket
May 7, 2016
67
Easton, Pa
I just purchased the springs that you are talking about, for the same repair. Timesavers sells them for $1.00 each. Part# 10567 for left time side & Part# 10568 for right strike side.
expeditionhiker
Jan 4, 2017
66
wow, was not expecting to find the part, just ordered, thanks! Although part of me was looking forward to making the spring...
Support the NAWCC
Forum Expense plus NAWCC
Goal
$1,000.00
Received
$360.00
36%
Host server
$250.00
Software support
$250.00
NAWCC operations
$500.00
Expenses
Latest posts
181,330
1,582,210
54,774
Jim Lampros
3,126
Top
