ogee tablet
Discussion in 'Clock Case Construction, Repair & Restoration' started by Kevin W., Oct 14, 2005.
Tags:
  1. Kevin W.
    Kevin W. Registered User
    22,603
    386
    I have a old ogee clock and i replaced the tablet, i looked at the top glass and it looks like putty was used to hold it in.Is the putty the way to go for the tablet also?
    Probaly a dumb question but i am new at this.
  2. Kevin W.
    22,603
    386
  3. Past Tyme
    Past Tyme Registered User
    Dec 29, 2004
    40
    :)Hi Kevin
    I would use small wood strips myself makes life easier if you ever need to replace it again.I stain the ones I use a color too match the finish of the case or close to it.It usually makes no difference especially if you are keeping the clock for your own collection.This is only my opinion,I'am sure others have different thoughts.
    :biggrin:Cheers Shawn
  4. TomT
    TomT Registered User
    Jan 2, 2003
    446
    You might want to examine the door where the glass will be fitted with a good light. If you find holes from prior nails, then the wood strip approach is what was originally used. If there are no nail holes on the sides or bottom of the glass area, then putty would have been the original mounting method.
    I would try to stay as original as possible just to maintain historical accuracy. Someday, your kids or grandkids may become collectors of your clocks and would likely appreciate your respect for accuracy.
