Hello, my odo has arrived yesterday. This clock a 24/111 (movement 24/111 type gong) ODO clock. The clock has some missing bits and pieces. The case is decorated with a “scroll work?”.
Unfortunately, longest chime rod has broke. Even we had told them to secure the chime so it doesn’t break. What they did is they stuffed the clock with paper and somehow pushed the movement/seat board in at an angle. Luckily, we got it out fine and we had 300 dollar insurance so we have to deal with that.
The movement is looks to be in fine condition but one of the split plates were expanded so I had to fix that. It has a lever at the bottom of the movement that changes the chimes. There are not any strings for silencing but a lever that you move. The movement is stamped “24”.
I think the dial is in great condition, do you think so?
The pendulum looks different? It looks to be missing something or is this just the new stuff?
The key is large (like a vedette key). Is it original? You can see in this pic.
The seat board screws were missing so I used a vedette screw to secure the movement.
One of the side hooks are missing to close the door. One thing to note is the clock does not close completely since it hits the dial for some reason. No pictures for this.
The stabilizers are missing too. Where should I find this?
What is this screw for? It doesn’t attach to anything.
Here are the chimes: The hour chime is a bim-bam melody and a bit weak because the chime rod is missing. (Hope you like them! Note there is some notes out of sequence I think.)
Do you think this is a good find? What do you think?
Thanks in advance for comments or answers/feedback.
