Seth Thomas Odd Seth Thomas Tambour?
Savageblunder
Nov 10, 2019
52
11
Gilbertsville PA
Found this at a yard sale. It’s a Seth Thomas - but can’t seem to locate on line it online. First, it’s huge. But the movement isn’t an 89 or similar. The plates are round - not square. Also, it’s not Westminster chime - standard gong. The glass on the bezel is beveled. The color of the case seems off to me as well. Doesn’t look refinished but who knows?
Isaac
Aug 5, 2013
973
182
We'll need to see the movement. Most likely it is either the round 8 day movement they used in their crystal regulators, or their high grade 14-day movement. Most likely will strike on their "Bell-metal" gong, which has good resonance and sound.
Savageblunder
Nov 10, 2019
52
11
Gilbertsville PA
386015DA-1A1C-400F-A6E7-B3E90B2538D8.jpeg 31E40AE5-D084-40F2-9F64-584402C870CF.jpeg 1F93FEB3-C1E1-447B-87B5-31CD9E2BC303.jpeg 5EA97104-7FCB-4C15-9F6B-2D3AED331EC6.jpeg
Upon close inspection, clock was refinished. I measured it - it’s huge 29” long & 12” high. No markings on the back of the movement I can see. No stickers on clock anywhere. Movement was overhauled in 2008 apparently.
The springs are in barrels & it looks like you can replace the springs without separating the plate. Whatever movement this is it’s almost silent.
Seems like most ST clocks like this I see online approaching this size are Westminster chimes - but have yet to see one anywhere near 29” long. Maybe I just haven’t looked enough
Isaac
Aug 5, 2013
973
182
It looks exactly like a New Haven round movement that they used in their crystal regulators. I don't see a name on the dial (Seth Thomas always put their name on their clocks), so I'm going to say that New Haven is the manufacturer of this clock instead of Seth Thomas.
It should run for an 8 day duration.
Savageblunder
Nov 10, 2019
52
11
Gilbertsville PA
Maybe I’m loosing my mind. I swore it said ST on the dial, but looking after your post it does not. Maybe I got confused because the seller I got it from had other clocks I was considering with ST on the dial? I’ll search New Haven thanks.
Whatever it it, the movement is very quiet
Topic related ad experiment
