Re: 400 Day Schatz clock face screw holder assembly
H/C
Have you thought of making these ??
H/C
All you would need is some round stock a tap and a drill and drill press. You could even part them off on a drill press . I don't do this practice but it could be done. But dimensions are important.Have you thought of making these ??
H/C
You may want to try Ace hardware for those tiny screws. But I do believe that 1/32 is extremely small. These are the small rings that hold the face to the movement.Ok - sorry for the delay - the brass collars would be easy to make but the problem is the teeny tiny set screw. I have access to some brass sleeve that would work but the screw is the problem. I currently have the original sleeve but the tip of the original screw is broken off.I've tried to measure the brass collar and I get .196 OD and .110 ID - I'm not sure I'm measuring correctly since I do not have an inside micrometer but it works out to about 7/32"" OD and 1/8" ID with a thickness of 1/32". Sorry I do not have a great micrometer and plan to purchase a better one in the future. The hole opposite the screw is not needed - I believe it was just easier for Schatz to make it that way. I have no idea where I could find a screw this tiny. Thanks so much for all your help.
John
John, try out this page,the screws are at the bottom.Ok - sorry for the delay - the brass collars would be easy to make but the problem is the teeny tiny set screw. I have access to some brass sleeve that would work but the screw is the problem. I currently have the original sleeve but the tip of the original screw is broken off.I've tried to measure the brass collar and I get .196 OD and .110 ID - I'm not sure I'm measuring correctly since I do not have an inside micrometer but it works out to about 7/32"" OD and 1/8" ID with a thickness of 1/32". Sorry I do not have a great micrometer and plan to purchase a better one in the future. The hole opposite the screw is not needed - I believe it was just easier for Schatz to make it that way. I have no idea where I could find a screw this tiny. Thanks so much for all your help.
John
Cool! You wouldn't have a side panel for a Schatz Bermuda Carriage would you?I sent a pm to John on the clock part, i think i have what he needs. Trying to help a fellow clockie.
Yes!You mean the plastic part that goes in the frame of the case.
Jay who supplies these partsJohn, try out this page,the screws are at the bottom.
http://www.pmclocks.com/Acrobat/HdwrAssortments.pdf
PM ClocksJay who supplies these parts
H/C
Thanks Jay.PM Clocks
