Hi, I recently found a New York Standard Watch Co. electrically driven clock.
I have a couple of questions for other collectors with this most unusual clock.
I'm running it with 3.3 VDC via a #6 dry cell adaptor from Mike's Clock Clinic. Thanks Mike.
I have a impulse cycle of 1:22 What have other owners found to be the best cycle from their adjustments.
I have the Hipp Toggle "flipper" set to engage the knife edge attached to the pendulum crutch, just about in the middle vertically, and hang, when at rest, just to the right side of it.
I have the contacts set about .025 apart. When they make, I adjust the fixed contact to insure when they operated, the fixed contact has a good amount of "follow". This is when the fixed contact is pushed a bit when operated. This will cause a sliding effect to the contacts, to help keep them clean. And enough pressure to insure a good solid connection, to help avoid arcing.
I'd enjoy hearing from other owners.
Here is a youtube of the Hipp in action:
https://www.youtube.com/watch?v=xTu9SapKtKw
