Now There are Two...
Discussion in 'Your Newest Clock Acquisition' started by Selenaserval, Jan 21, 2018.
  1. Selenaserval
    Selenaserval Registered User
    Jan 9, 2018
    25
    Female
    Jeweler, Disaster Recovery Coordinator
    Washington State
    So now there are two cuckoo clocks in my collection. I just bought an old Albert Schwab that runs well. It's missing a detail from the upper left roof line, but I'll carve a replacement. Does anyone know how old it might be? Thanks so much for your input.
    cvanderslice69 and sylvester12 like this.
  2. JTD
    JTD Registered User
    Sep 27, 2005
    7,642
    509
    We really need to see the movement.
    JTD
  3. Selenaserval
    Jan 9, 2018
    25
    Female
    Washington State
    Thank you JTD. I should have posted more pictures.
    Cuckoo Albert Schwab movement.jpg Cuckoo Albert Schwab gong door.jpg Cuckoo Albert Schwab mounted on cabinet.jpg
  4. JTD
    JTD Registered User
    Sep 27, 2005
    7,642
    509
    Well, we can see that the movement is a Regula (Josef Burger Söhne), nowadays the most common manufacturer. But I am wondering about the extra holes we can see in the case. But I am not a cuckoo clock specialist - other will have more ideas for you than I.
    JTD
    Selenaserval likes this.
  5. Selenaserval
    Jan 9, 2018
    25
    Female
    Washington State
    Ok, thank you so much JTD. Now I am wondering about the extra holes in the case! Lol :)
  6. roughbarked
    roughbarked Registered User
    Dec 2, 2016
    4,516
    431
    watchmaker
    Looks like the Regula is a replacement movement.
  7. Selenaserval
    Jan 9, 2018
    25
    Female
    Washington State
    Thank you very much Roughbarked. The dealer who sold me this clock said she bought it from an estate and was told that it was from the 30's.
  8. harold bain
    harold bain Registered User
    NAWCC Member Deceased
    40,850
    162
    deceased
    Yes the movement is much newer than the case. Shame someone thought replacing the original would be a good idea.
  9. Selenaserval
    Jan 9, 2018
    25
    Female
    Washington State
    Alas, all I have is a nice looking old clock case, and a newer movement to be sold or placed in a different and more appropriate clock case. So I will attempt to find an older movement for this case if I can determine what type it should have. Any advice would be greatly appreciated. Thanks Harold Bain, and all who have provided me with information so far.
  10. Selenaserval
    Jan 9, 2018
    25
    Female
    Washington State
    Last night I removed the ancient torn leather from the bellow on the left side and replaced it with paper from a priority envelope, and put a little weight on top of the bellow. It works well now. I had the clock running, but it has a number of issues, and only runs for a little while. The minute hand is loose. It cuckoos whatever number of times strikes its fancy, but mostly not at all. It never cuckoos on the half hour. It doesn't gong, (it may only need an adjustment to the striker arm). The bird doesn't come out, and the door opens every now and then. On a happier note, my Hubert Herr clock is in perfect running condition and everything works - - knock on wood. ;)
  11. gleber
    gleber Registered User
    Jun 15, 2015
    1,787
    212
    Underwater Robotics Expert
    Downingtown, Pennsylvania USA
    That's a nicely carve case, and like others, I think the movement is later.
    Regarding the running condition, You might want to post details in the Repair section for better replies, but I think most people who frequent the repair section can also be found here.
    Anyway, Let's try to break it down a little. Are you familiar with setting the beat? If so, have you done any other checking of the movement for bushing wear or sticking wheels (have you cleaned or oiled the movement)?
    Have you tried with the movement out of the case. A lot of times these movements have levers in the front that can hang up on the case, especially if the movement is a replacement.
    Hopefully, we can help you get this one running like your Hubert Herr.
    Tom
  12. Selenaserval
    Jan 9, 2018
    25
    Female
    Washington State
    Thank you Tom. I'll move over to the repair section for further assistance. Good news to report. I opened the clock case again and the wire that pushes the cuckoo door open had disconnected itself. I glued the little screw eye back into the door, and reattached the wire. I fixed the hinges on the door, and put the cuckoo lift wire into a better position. In addition, I found that the arms that lift the bellows were hanging up on each other, so I corrected their positions. I took the hands off and set them in the right position for the timing of the cuckoos. After re-hanging the clock and starting it up, it is not stopping any more, and keeping the right time. The bird comes out now and cuckoos on the hour. The Regula movement must be in pretty good shape after all. Again, many thanks for your advice. As a novice, I can't believe I got this clock running so well, and that my first bellow rebuild is functioning as it should. :)
  13. roughbarked
    Dec 2, 2016
    4,516
    431
    watchmaker
    Believe it. You did it. :)
  14. Selenaserval
    Jan 9, 2018
    25
    Female
    Washington State
    Thank you so much Roughbarked! :) I'm so happy - - especially when I'm in another room and I hear the older clock cuckooing, just after my Herr has gone off.
  15. gleber
    Jun 15, 2015
    1,787
    212
    Glad to hear you were able to get it going and without too much stress (nobody needs more stress). We all start as novices. A little patience, determination and common sense is all that is necessary and it sounds like you are off to a good start.
    Tom
  16. harold bain
    40,850
    162
    deceased
    I think you may have a knack for this. Good job so far.
  17. Selenaserval
    Jan 9, 2018
    25
    Female
    Washington State
    Thank you so much for the words of encouragement Tom and Harold. I'm glad I found this forum. There are some kind and knowledgeable people here.
  18. bruce linde
    bruce linde Technical Admin
    6,744
    817
    oakland, ca.
    i started as an apprentice novice...
  19. gleber
    Jun 15, 2015
    1,787
    212
    That's because you are a dog (at least according to your profile pic).
    Tom
  20. bruce linde
    6,744
    817
    oakland, ca.
    Well, the incarnation before the dog was a cockroach… reincarnation doesn’t always work out how you planned! :)
  21. woodlawndon
    woodlawndon Registered User
    Jan 18, 2017
    680
    168
    Woodlawn, Ontario
    Nicely done. This is the buzz of getting an old clock to work again, it's so satisfying. I'm only a few months ahead of you but it will keep getting better with the more clocks you will inevitably gather. It's a great hobby and the folks on this site are truly craftsmen willing to help.
  22. Selenaserval
    Jan 9, 2018
    25
    Female
    Washington State
    Ah, the cuckoo buzz. Lol at least I'm in good company here, with others who understand. :) Thank you Woodlawndon.
  23. roughbarked
    Dec 2, 2016
    4,516
    431
    watchmaker
    :) Yep. It is a buzz.
