Not a knurling tool.........
glacey
Dec 5, 2009
11
Hawaii
Hi All, before this arrived I thought that it was some sort of hand knurling tool. When it arrived I realized that it isn't! The knurled nuts are tight but can be loosened but that doesn't seem to be the way that, whatever this is, should work. The single knurled nut and long bolt lifts or closes the one knurled nut so that something could be gripped between it and the other, opposing knurled nut-but as mentioned the two opposing knurled nuts don't rotate when tightened into their positions so it grips as opposed to rotating and knurling.
There is an additional knurled nut on the back (if that is the back?) but that may have just been the only nut that fit the bolt-it may or may not be what should be there.
Because of the rings around the bottom holes maybe this tool was attached to a bigger tool? BTW, it is about 4" long and about 1 1/2 " wide.....I'd appreciate any suggestions, thanks.
gmorse
11,835
1,810
Hi glacey,
My vote is for a case back wrench; there are pins on one end of the knurled pieces and blades on the other, and I suspect that the tool originally had a selection of these inserts for different case patterns.
Reactions: measuretwice
glacey
Dec 5, 2009
11
Hawaii
Thanks Graham. Yes, that makes sense. I had been concentrating on the knurled nuts as the operating items without thinking that the ends are the operatives. Your mentioned inserts would be screwed in by gripping the knurled parts. So the two empty holes could also hold additional inserts to vary the pattern.
So I now need a knurling machine even more to replace the modern nut! :)
Thanks again
George
Topic related ad experiment
160,720
1,394,719
82,818
fatherted
1,099
2,778
