I have an 8 day Sessions mantle time and strike with a noisy fan wheel when striking. I think the noise is from where T4 wheel contacts the lantern pinion of the fan. I think the lantern trundles sit too low in the teeth of T4. The fan bushings are original. I can eliminate the noise by gently raising the pivot of the fan assembly. There is not excessive play in the fan or T4 bushing. Is the solution to raise the fan wheel with new bushings?
