Pocket: No Words Required
Discussion in 'Chronometers' started by gmorse, Mar 17, 2016.
  1. gmorse
    gmorse Registered User
    11,257
    1,565
    Retired from Xerox
  2. MartyR
    MartyR Registered User
    Dec 16, 2008
    11,041
    307
    UK
    What an incredible film! I've bookmarked it now - thanks Graham :thumb:
  3. Tom McIntyre
    Tom McIntyre Technical Admin
    Aug 24, 2000
    82,669
    1,600
    176
    retired SW dev
    Boston
    Thank you so much Graham. I had lost track of John's work after the Longitude Symposium and had not seen anything of his output since then. The Emmanuel chronometer is truly an amazing exposition of the chronometer escapement. The other short clips on his web site are also pretty wonderful. I may need to do some tracking to find the longer versions and animations of the ones he did as work for hire.
  4. MrRoundel
    MrRoundel Registered User
    Dec 28, 2010
    1,201
    157
    So. Cal., USA
    No words possible. And that's from one known for verbosity. Thanks for sharing this very timely (for me) link. I've been trying to understand the workings of the spring detent in my Hamilton model 21, and that animation put it right there in front of my eyes. It's exactly what I was hoping for. Truly world-class animation. I'd have to say it was perfect. So there's a word rightfully well-reserved, and in this case, well-deserved. Cheers. :clap:
  5. doug sinclair
    doug sinclair Registered User
    Aug 27, 2000
    14,364
    55
    Calgary, Alberta
    A masterpiece esthetically and technically! Thank you for sharing. As you said, "no words required!"
  6. novicetimekeeper
    Jul 26, 2015
    9,844
    619
    Dorset
    Is that what that type of escapement is called, chronometer escapement?
    Why does there need to be the dummy pass where the strip is pushed out of the way? What does the strip do that can't be done without it there?
  7. gmorse
    11,257
    1,565
    Retired from Xerox
    Hi Nick,
    Have another look at the video; if the gold passing spring wasn't there, the detent locking stone would be crashed into the escape wheel on the clockwise swing of the balance. The balance only being impulsed on the anticlockwise swings gives it the maximum possible degree of detachment.
    It is called a chronometer escapement, or "spring detent", and this one is based on Thomas Earnshaw's design, which you'll notice locks with the detent in compression. I know that looks counter-intuitive, especially considering the thickness of the spring supporting the detent, but it's been found to give the best performance.
    But isn't it exquisite?
  8. novicetimekeeper
    Jul 26, 2015
    9,844
    619
    Dorset
    Exquisite it definitely is. Thanks for the explanation, I'll take a closer look again. I had heard of spring detent now I know what I am looking at.
  9. doug sinclair
    Aug 27, 2000
    14,364
    55
    Calgary, Alberta
    That has been called a spring detent escapement (there is also a pivoted detent escapement), a "chronometer" escapement, and/or an Earnshaw escapement. This type of escapement gives impulse to the balance wheel only every second beat of the balance. The spring you refer to is often called a "bypass" spring. The video calls the jewel that activates that spring as a "dummy pass" jewel (often called a "bypass" jewel) that fits into a roller on the balance staff. In one rotation, the bypass jewel pushes the bypass spring aside and completes its cycle. On the return trip, the bypass jewel pushes against the bypass spring which pushes the detent aside, allowing the detent jewel to unlock a tooth on the escape wheel. While this is happening, a trailing tooth on the escape wheel comes in front of the impulse jewel in the impulse roller (also on the balance staff), giving the balance an impulse, when the detent jewel releases the escape wheel. The detent jewel returns to a locking state immediately, once the bypass jewel releases to bypass spring, to stop the very next escape wheel tooth. Then the whole operation repeats. If you observe the arms on the escape wheel in the video, you can observe the escape wheel turning. You don't see it turn if you watch the teeth of the escape wheel because everything happens so fast! I am certain the animation should be easier to understand than my description!
  10. Paul Regan
    Paul Regan Registered User
    Mar 4, 2003
    701
    58
    Florida
    Thank you Graham, that was amazing!
    Paul
  11. Tom McIntyre
    Aug 24, 2000
    82,669
    1,600
    176
    retired SW dev
    Boston
    The terminology I am familiar with is the "passing spring", the "impulse jewel" and the "unlocking jewel". The geometry is very intentional with the unlocking jewel having the shortest action radius so it takes the least energy from the balance and the impulse at a much larger radius to have the briefest period cf contact between the escape wheel and the balance. i.e. the greatest detachment.
    As Doug mentioned when looking at this in real time, you cannot see the teeth move on the escape wheel. It looks like only the spokes move. If you can see the teeth move the watch needs servicing.
  12. richiec
    richiec Registered User
    Feb 24, 2007
    6,707
    532
    automotive warranty inspector
    Brick, Ocean, NJ
    Oh where do people find the time and energy to produce such great things. thanks, Graham.
  13. Accutronitis
    Accutronitis Registered User
    Aug 24, 2014
    494
    Las Vegas
    Truly we live at a great time when people can be shown the never before seen in such great detail and in many different ways which in turn allows the average person to learn and understand how and why things work like never before and it will only get better in time, Take for example IBM's "Watson" and where that is heading and how great it would be to ask any question in any natural language and it understands what your question is and it searches all the accumulated knowledge of mankind and in no time at all it can give you the answer in a number of different ways, If anyone has seen the movie "AI" they will certainly remember this line "Ask Dr. Know. There's nothing I don't", how great that will be some day......
