When putting my Nissing Master back together I ended up with an extra washer, one I think has to do with the motion work. I tried putting it a few places but it didn't work (it jammed everything up). It's the lone washer at the right of the picture.
I thought it was from the motion works on the center arbor, but the following works fine (from bottom to top): cannon pressure washer, cannon pinion, hour wheel, hour hand, minute hand, hand washer, hand nut.
I tried adding it under the minute wheel screw but no luck, it jammed the minute wheel.
Any suggestions?
Any suggestions?
![20191226_121127[1].jpg 20191226_121127[1].jpg](https://mb.nawcc.org/data/attachments/480/480651-2be5a3c2832dbdd4c8b241d5b0041879.jpg)
![20191226_121139[1].jpg 20191226_121139[1].jpg](https://mb.nawcc.org/data/attachments/480/480652-3dff93ab0fe057716ecfdf455584e8c1.jpg)
![20191226_121212[1].jpg 20191226_121212[1].jpg](https://mb.nawcc.org/data/attachments/480/480653-f4099ef969c3de0604da03ec5bf5e00e.jpg)
