Nice Walnut Case!
Discussion in 'General Clock Discussions' started by TheTickTockDoc, Apr 17, 2020.
  1. TheTickTockDoc
    TheTickTockDoc Registered User
    Oct 9, 2009
    599
    25
    New Port Richey, Florida USA
    Hello Friends:
    I recently picked up this very nice walnut case. I don't know if it was a kit...or what? It's 57" long with a 12" dial space. Can't say that I've seen one like this before. The quality of the wood and the expertise in which it was put together is fist class....maybe it was made by some cabinet maker? I'd like to put a mechanical movement in it...but the pendulum length is a problem if I want to pull something out of another clock. Looks like about a 40" pendulum. Really no room in the neck for a weight. Any ideas? Have any of you seen anything like this? As always, thanks in advance for your suggestions and expertise. Best regards, Rich
  2. rmarkowitz1_cee4a1
    Nov 26, 2009
    5,095
    841
    Many interesting possibilities!
    Reminds me of a dachluhr??
    Be fun to find a nice old weight driven movement?
    RM
  3. Jim DuBois
    Jim DuBois Registered User
    NAWCC Member Sponsor
    Jun 14, 2008
    2,825
    566
    Magnolia, TX
  4. jmclaugh
    jmclaugh Registered User
    Jun 1, 2006
    4,677
    121
    Devon
  5. TheTickTockDoc
    Oct 9, 2009
    599
    25
    If you might have a movement for this case, please let me know!
  6. TheTickTockDoc
    Oct 9, 2009
    599
    25
    The neck dimensions make it hard to put in a movement with weights. It's only 6" wide and 2 3/8" deep.
  7. PatH
    PatH Registered User
    NAWCC Fellow NAWCC Member
    Dec 5, 2014
    1,655
    1,139
    Female
    Texas
    Is there a seatboard, or evidence of a movement having been mounted in the case previously?
  8. Willie X
    Willie X Registered User
    12,774
    983
    TTD,
    You will be looking a long time to find a movement for that case. That case was built around the the movement.
  9. TheTickTockDoc
    Oct 9, 2009
    599
    25
    There is not a seatboard. There has never been a movement in it. It was an unfinished project I am told. Putting a seatboard in is no problem....it's just that there's not enough room in the neck for weights. All of the other wall clocks I own, or have seen (ie Vienna regulators)...the pendulum is way too short to use in this case. I have this HM wall clock in which I can use the movement for a reference......the length of the pendulum is right...but there's no way to fit any weights into the neck. I may have to put in a quartz movement.........not really what I want to do.....
  10. jmclaugh
    Jun 1, 2006
    4,677
    121
    Devon
    So is there not enough room for a single weight and a pendulum to pass through the neck?
  11. TheTickTockDoc
    Oct 9, 2009
    599
    25
    It's only 2 3/8" deep.....
  12. jmclaugh
    Jun 1, 2006
    4,677
    121
    Devon
    Shame, spring driven then.
  13. TheTickTockDoc
    Oct 9, 2009
    599
    25
    Yes....I think that's what it's going to have to be...now to find a movement with a very long pendulum......any ideas?
  14. TheTickTockDoc
    Oct 9, 2009
    599
    25
    Hello friends: Just a follow up to this post. After an exhausting search, I decided to go with a Hermle 141/070 94cm movement along with an HPL 04-115 pendulum. Black Forest was very helpful working on the pendulum lengths, etc. It all fit with hardly any room to spare. I had to cut out some of the interior bracing so the pendulum wouldn't rub. Installed a dial pan, paper dial and the customer wanted the hands painted gold. Painted the dial glass like a store regulator and installed. The customer wanted no decoration on the middle glass that I installed, and I went with a Merrit's painted glass for the bottom. About 17.5 hours to finish.
    Levi Hutchins and PatH like this.
  15. JTD
    JTD Registered User
    Sep 27, 2005
    7,499
    486
    I think it looks very fine indeed - you have done a great job.
    JTD
  16. PatH
    Dec 5, 2014
    1,655
    1,139
    Female
    Texas
    Nice save. Thanks for sharing the solution.
