Newly acquired Ansonia
Discussion in 'Your Newest Clock Acquisition' started by dg23662, Mar 1, 2017.
  1. dg23662
    dg23662 Registered User
    Jan 26, 2012
    Just acquired this Ansonia kitchen at an auction and was wondering what the model and appox. date it was made. There is a picture of what is left of the tag on the back. also does anyone have any ideal what the metal object is that is leaning on it. Does it go with this clock or is it for a clock at all. Thank you in ad[​IMG][​IMG][​IMG][​IMG][​IMG][​IMG]vance for any help.
    Attached Files: Download all post attachments
  2. blindraccoon
    blindraccoon Donor
    Jun 6, 2014
    190
    Hi dg, I don't have an Ansonia 'book' here so I can't answer your question pertaining to model, but I will say that you acquired one very
    n-i-c-e mantle/kitchen clock! I've never seen the fancy brass appliques that your clock displays. Really pretty and quite eye-catching!
    Blindraccoon aka Laurie
  3. George Nelson
    George Nelson Registered User
    Oct 5, 2007
    884
    #3 George Nelson, Mar 2, 2017
    Hi, dg
    I agree totally with Laurie- your clock is a wonderful example! Very nice, and a bit uncommon. One often sees the typical "parlor" clock, but this one is very well executed, and, as mentioned, the brass adornments are both detailed and quite complimentary to the overall look. Typically, brass or metal add-on pieces seem to be an afterthought, applied solely to increase a first impression, not necessarily a true compliment to the case design itself. In the case of your clock, the decorations are quite well done, and truly enhance the overall appearance of the piece.
    As for the metal item you ask about, it does not go with your clock, but seems to me to be part of the top of an anniversary-type clock, the kind with the rotating pendulum and usually presented under a protective glass dome.
    Lacking an Ansonia catalog, my personal estimate as to age would be late 1800s, most likely 1890 through possibly 1910 or so.
    Enjoy your clock-she is indeed a beauty!
    Warmest regards,
    George Nelson
  4. shetalksaboutclocks
    shetalksaboutclocks Registered User
    Aug 20, 2016
    19
    I'll be interested when you figure it out. If you don't want to buy a book just for this one clock, I'd recommend going to your local library and seeing if they can do an interlibrary loan for the Tran Duy Ly book on Ansonia or for some old Ansonia catalogues. That's how I dated my two Ansonia clocks.
Similar Threads - Newly acquired Ansonia Forum Date
Newly acquired Gustav Becker Mantle Clock & Candelabra Set Your Newest Clock Acquisition Jan 25, 2017
Newly acquired Vincenti Your Newest Clock Acquisition Jan 11, 2017
Newly acquired USSR manufactured Codeg Clock kit - minute hand nut size help request. Your Newest Clock Acquisition Nov 11, 2016
Newly acquired ingraham Your Newest Clock Acquisition Aug 25, 2015
My newly acquired Gustav Becker !! Your Newest Clock Acquisition Jan 25, 2014
