Newer 400 day clock.
Discussion in '400-Day & Atmos' started by bcaclock, May 17, 2017.
  1. bcaclock
    bcaclock Registered User
    Feb 20, 2001
    255
    Clock Maker
    Mt. Pleasant, Tx.
    There is no beat adjustment screw on this movement. IT WOULD APPEAR THAT YOU MUST MOVE THE NYLON VERGE. How do you make micro adjustments by moving the verge? I've repaired many but never one like this. Mickey mouse:???:
  2. JTD
    JTD Registered User
    Sep 27, 2005
    3,944
    19
    Could you post a photo please?
    JTD
  3. shutterbug
    34,325
    Yes, it might be an older model without the adjustable suspension.
    I'll move this over to the 400 day forum.
  4. MartinM
    MartinM Registered User
    Jun 24, 2011
    2,314
    10
    El Dorado, CA
    Depending on the design, the suspension may not (Probably doesn't) have any impact on the beat or regulation of the clock.
    Assuming it's a battery powered clock, there was only a period of a couple of years for a couple of makers where regulation was tied to the pendulum.
  5. bcaclock
    Feb 20, 2001
    255
    Clock Maker
    Mt. Pleasant, Tx.
    It is a standard 400 day movement (not quartz) except no adjustment screw on the suspension spring top block hanger. The verge is nylon and is moveable on the shaft but how do I make micro adjustments as all 400 day movements need for beat setting? It is a Haller movement if that matters.
  6. shutterbug
    34,325
    We really need a picture of the clock. I'm concerned that it may be the infamous "German Time Bomb". Don't do anything with it until we can make that determination.
  7. harold bain
    Donor NAWCC Member
    39,942
    Perhaps the whole "top block hanger" can be moved??
    This doesn't sound like a "German time bomb" type movement to me.
  8. bcaclock
    Feb 20, 2001
    255
    Clock Maker
    Mt. Pleasant, Tx.
    I hope this picture will upload. I knw it islousy but maybe it will lwork.
  9. harold bain
    Donor NAWCC Member
    39,942
    Can't you move the part that the top block is in to set the beat?
  10. KurtinSA
    KurtinSA Registered User
    Nov 24, 2014
    1,687
    Aerospace Engineer
    San Antonio, TX
    Interesting...another one of our members is from Mt. Pleasant, TX. What are the odds...in that small town?? Maybe he'll stop by the forum and offer some input or work out a local visit and help out. Nutjob
    Kurt
  11. DieteR
    DieteR Registered User
    Sep 18, 2008
    114
    Hello
    It semes to be a normal Haller movement. I am sure.
    While writing this text, I am just looking at exactly such a movement.
    You can and You must move the top block, to set the beat!
    It will need a little power, maybe it has been turned never before.
    DieteR
  12. shutterbug
    34,325
    That seems the easiest way. The pic shows the block inserted into the part that needs to be turned. Grasp it with fiber jawed pliers if you need a bit more persuasion to get it to turn.
  13. MartinM
    Jun 24, 2011
    2,314
    10
    El Dorado, CA
    You should be able to insert a small screwdriver into the slot of the saddle just above the top block to gain the leverage needed to turn the saddle on the rivet.
  14. mjstewart
    mjstewart Registered User
    Feb 20, 2016
    12
    I agree with the previous posters. However you may want to inspect the "verge". If it moves too freely it may be cracked. I have been burned by a cracked nylon anchor on these S. Haller clocks. There are several suggestions in older threads on solutions to this problem. ( Looking closely at your picture I suspect a crack at the bottom of the plastic)
  15. shutterbug
    34,325
    I see what you mean. It does look cracked at the bottom.
Similar Threads - Newer clock Forum Date
General Thoughts on Getting a Clock to Run 400-Day & Atmos Monday at 8:38 PM
Schatz 1000 day clock runs for 15 minutes and stops 400-Day & Atmos Thursday at 1:32 AM
First Torsion Clock 400-Day & Atmos Oct 10, 2017
mini kundo 400 day clock suspendion 400-Day & Atmos Oct 6, 2017
Does the newer 400 Day Repair Guide have mainspring listings? 400-Day & Atmos Aug 16, 2010
