Hi all,
Questions from the newbie again so I apologize in advance for the kindergarten level of the post,
I just completed a disassembly, cleaning, and reassembly of thrift shop Junghans Westminster that the chimes and strike were running on under power (meaning only that they moved robustly in what appeared to be the correct manner when the minute hand was cycled through the hour), but the going train displayed no signs of life in the tick-tock variety. I followed Al Takatsch's 8 hour video for the same movement on Patreon throughout. It was very helpful but the setting up of the chime and strike parts on the face of the front plate wasn't slow enough or filmed clearly enough for someone as new as I am, so I probably botched that part. Overall it was a great learning experience in terms of splitting plates and getting what was my first 3 train movement back together (my neck is still sore from peering through those plates so long), but it has left me with so many questions.
I reassembled the movement and everything seemed to be moving as expected under hand pressure okay. I put in the time barrel only in and gave it some power and it started to run, and seemed to be running strongly when the pendulum was added on the test stand. I then added the chime and strike barrels and now it will only weakly and briefly run, and only go as it did on the test stand if I apply positive pressure to the minute hand.
This clock had a bent center arbor that I straightened to the best of my ability, could it be that just too much drag is still remaining from my attempt? Or can a chime assembly wrongly configurated interfere with a healthy beat?
This is a clock purchased for educational purposes with who knows what else is wrong with it, and undoubtedly needs rebushed, but was wondering if anyone could give me some take away thoughts to ponder as I go forward. Will be setting this movement aside while I continue to read and watch videos, hopefully to be revisited sometime in the future when I have some notion of what I am doing.
Thanks everybody for this wonderful forum and any and all responses you may have will be appreciated,
Jessica
Jessica
