Hi,
Happy to join this fabulous forum. I have read a lot of posts. Great place.
I have a mantle clock kit I finished and assembled when I was younger. It hadn't been running in years. It is a three wind chiming clock with an Erhard Jauch clock movement.
I removed the movement and followed some oiling instructions I found and it started up and seemed to run like new except that the speed is insanely fast. It gains 30 seconds every 60 seconds and there appears to be no way to slow it down using the lever on the balance wheel.
Moving the lever toward plus or minus makes no change. The other little arm attached to the lever I can move as well, but it makes no difference. I have attached some photos and would appreciate any help you could provide.
Thanks,
John
Thanks,
John
